Originally Posted by ZO6/Les
Reliability should not be an issue ... maybe more valve spring replacements needed depending on how much lift you go with, but that would be about it - assuming you get it tuned "right".
Les
Agreed, except if you're like me then you'll have to keep constant restraint from making her "talk to you", which might bring a rebuild a little closer.
Really though, without beating on it, I'm with Les....just the valve springs ~10-15K depending on cam.
NCM # 23306 Fest Member 2, 3, 4, 5, 6, Ocean & WinterFest 1 & 2
