Engine cooling problems, need help
We recently installed a 383 and are having some issues with the cooling system...
Motor:
New 2004+ LS6 Block
Eagle crank
Scat Rods
Diamond pistons
2002+ GM MLS Gaskets< Is there is different gasket we should run for the 2004>
AFR 205 heads
G5x3 cam
Stock water pump
90/90 setup
we also replaced the engine coolant temp sensor with a Carquest temp sensor
When we started it up for the first time, we added coolant as we normally do and everything looked fine
Engine coolant temps came up to operating temps normally but once it got to 180-190 where it should have stopped, it kept going up until it sat @ 225-235.
Things we noticed..
The system seemed like it had an excessive amount of air...
Upper radiator hose didn't seem like it was full of coolant
No coolant smell out of the exhaust
Oil pressure 55#
Every reading seems normal
Almost like something is blocking the coolant flow
Problem is the car warms up and won't move off of 230degrees, doesn't go higher or lower.
we've changed:
thermostat
Water pump and thermostat
