Old 10-12-2004, 10:29 AM   #1 (permalink)
Zed
Engine Failure...
I was coming back from relatives when it died... $500.00 tow truck ride back to town (3.5 hours away).
I'm trying to figure out what it is... I think it may be an intake gasket.
I pulled out to pass, I was in 4th gear, hammer down at about 5000 RPM when suddenly power dropped off and the car sounded like it was a diesel with the jake brakes on... sounded like the regular "decel" noise but loud and booming.
The car would not start after for more than a few seconds. I thought it was fuel because it was would run rough for about 2 or 3 seconds before stalling out (sounded similar to when I bled the fuel lines when changing injectors). Fuel pump turns on and I know it's getting fuel because it will start for a moment.
I don't think it's a valve or spring because there is no bad metalic sounds.
Anyone ever have this problem?
Car has 37,000 miles on it... most of them hard.
Zed
Chicks and Cars... what more do I need to say!
Bolt-Ons: 12.2 @ 116
Zed is offline   Reply With Quote
Old 10-12-2004, 10:39 AM   #2 (permalink)
I would think if you were to look at codes on the DIC you would find more than you care to think about and yet the problem could be something small. Keep us up to date on your situation.
Tony
02 Red/White/Blue Full Cage B&W Shifter T1 Suspension kit. 18"CCW Wheels Most Body Parts are Carbon Fiber
ELF Z06 is offline   Reply With Quote
Old 10-12-2004, 01:55 PM   #3 (permalink)
Zed
We pulled the valve covers off. I dropped a valve on the bank 1 (drivers side, front-most)... the spring snapped in half.
Its the first valve (the front most) is that the intake or the xhaust... I don't have the head off yet..
Zed
Old 10-12-2004, 01:58 PM   #4 (permalink)
Wow, that sux Zed. Hope you get it fixed quickly and painlessly.
Joe
My Garage
Old 10-12-2004, 02:22 PM   #5 (permalink)
Sorry to hear about your problems Zed. That's a real bummer as we use to say. I hope there is not too much damage and maybe you can get by with just a new spring.
BTW, do you have stock cam and valve springs?
Sig by the Hillbilly!
Old 10-12-2004, 02:39 PM   #6 (permalink)
Zed
Yup... stock... I haven't had the head off yet, but the stem is way down there... found the retianers and spring parts (they were still up top). I have about 37,000 high reving miles... I guess heat, high revs and milage add up quickly on those springs... we have an agressive valvetrain stock.
I'm thinking of forging everything now that I have to do this much. I'm assuming probably correctly that the piston is damaged it let go at 5,000 or 5,500 in 4th (I was passing someone).
Zed
Old 10-12-2004, 02:51 PM   #7 (permalink)
Zed
I'm pretty upset about it... I'm mostly broke at the moment to which sucks... probably be 3 or 4 months before I get another big check and I had different ideas about that check than rebuilding an engine... thats the way it goes I guess.
Zed
Old 10-12-2004, 05:12 PM   #8 (permalink)
Here's a pessimistic questions: Is there designed-in clearance between an 'all the way down valve' and an 'all the way up piston'? For a lot of engines, dropping a valve usually means metal hitting metal.
No Nails is offline   Reply With Quote
Old 10-12-2004, 05:25 PM   #9 (permalink)
2MchFun's Avatar
I dropped a valve in a big block back in the '70s. It ended up going through the cylinder wall and made a hole about the size of a 50-cent coin - it was not pretty.
I hope you have better luck Zed.
Old 10-12-2004, 06:51 PM   #10 (permalink)
A valve spring should last well past 37,00 miles even if they are hard driving miles. I don't know what mods you have, but sometimes manufactures pay a percentage of repairs if a problem occurs just past the warrenty period. I would contact GM about this. They may not pay anything, but it is worth a shot in my opinion. Sorry, to hear about your problems and I hope they are not as bad as you think.
Mike B is offline   Reply With Quote
Old 10-12-2004, 08:24 PM   #11 (permalink)
Trust me when I say, I understand your pain...
Harmonic Balancer Bolt Fell Out - Loss of Another Engine
Failed Timing Chain: Probable Cause, Correction and Pictures
Destroyed LS6: Cause and Pics
Good luck getting her back together.
Old 10-13-2004, 07:04 AM   #12 (permalink)
Zed
Originally Posted by Subdriver
I've followed all those threads when you posted them and said to myself "I won't have those problems, because I don't race"... should have knocked on wood.
Zed
Old 10-14-2004, 05:51 PM   #13 (permalink)
Zed
That's why I share them. While I still think the LS6 is a great motor, it isn't indestructable and I believe many of us drive them as if you were on a track much of the time...
Hoepfully the inside of your motor won't be too bad. When I broke my timing chain earlier this year, I didn't lose any pistons, only six valves.
Good luck.
When my timing chain broke I had six valves contact their respective pistons, some intake, some exhaust, so pretty sure the answer to that is there is no clearance.
Z06 Engine Failure - need input please Roger (SF) C5 Z06 - Grandstand 51 11-26-2006 01:10 PM
Death of my LS6 (2002 Z06, Valve keeper failure, engine destroyed) Keystone C5 Z06 - Grandstand 31 09-25-2005 06:42 PM
Who was that giving odds on another Dr. Electron engine failure, well guess what Dr.Electron C5 Z06 - Grandstand 26 06-05-2004 11:41 AM
SCCA MAM Race Report 4-25-04: First Contact/Engine Failure (Video Clips) Subdriver Racing 26 05-09-2004 09:08 AM
Terminal Engine Failure GalaxyEng C5 Z06 - Pit Road 7 10-26-2001 03:21 PM
