Old 08-16-2006, 06:31 PM   #1 (permalink)
Z06 Maniac!!
Lawdogg's Avatar
Is factory power steering fluid synthetic? Help
Anyone know, if it isn't synthetic is the synthetic stuff compatible?
'07 Z06 Lemans Blue
Old 08-16-2006, 07:43 PM   #2 (permalink)
I could not find much information, but I found this in my owner's handbook.
The Factory fluid is part number GM 1052884. Any Power Steering fluid that is compatible with that part number will work.:
I don't know if the factory fluid is synthetic or not. My guess is that it's not.
cheers:
I also found this
http://www.redlineoil.com/pdf/8.pdf
Old 08-17-2006, 05:42 AM   #3 (permalink)
Z06 Maniac!!
Lawdogg's Avatar
Thanks for the reply!` I guess we might just have to take our chances.
Old 08-17-2006, 07:15 AM   #4 (permalink)
DJWorm's Avatar
I recommend Sweet Mfg. Racing Power Steering Fluid, Full Synthetic.
Part# 301-30090
AMSOIL Online Store
Old 09-11-2006, 01:17 AM   #5 (permalink)
I believe the best GM ps fluid is a synthetic blend- not pure synthetic. I think it is called a "cold climate" ps fluid.
skeeter is offline   Reply With Quote
Old 09-11-2006, 07:54 AM   #6 (permalink)
DennyM's Avatar
Related question ...
Someone told me its a good idea to replace the PS fluid, as it breaks down under sustained high temps/use ...
Can one add synthetic or synthetic blend to what is stock fill?
Can one use the "turkey baster" method of cycling out the old fluid, as with the clutch master cylinder resevoir?
If not ... what is the drain process for the PS resevoir?
Power Steering Fluid Cooler marco383 C5 Z06 - Pit Road 2 11-09-2004 11:25 AM
Replacement Power Steering Fluid? EFI-1 C5 Z06 - Pit Road 7 09-14-2004 10:39 PM
GM Synthetic Axle Fluid bowtiebandit Member Sales - Parts & Cars 1 12-07-2003 11:59 AM
Which synthetic tranny fluid should I use? Cobra4B C5 Z06 - Pit Road 7 11-05-2003 09:15 AM
Synthetic Transmission Fluid ddle C5 Z06 - Pit Road 24 10-15-2001 11:43 AM
