Old 09-13-2001, 03:32 PM   #1 (permalink)
First oil change
Can you tell me how many miles you had on your car at your first oil change,and what % of oil life was left? I changed mine at 800 miles,the oil looked good , the oil life % was 93% I used the upf44 filter and 6.5 quarts of 5w30 mobil 1. Also,when checking oil before the change,the oil came to the top of the dip stick,at top hole.Now,it comes half way between the two holes? has any one seen the same? Also, car is in the same location,ect when the oil is checked. thanks for any and all input, steve.
QKSLVR is offline   Reply With Quote
Old 09-13-2001, 03:47 PM   #2 (permalink)
Re: First oil change
Quick,
Your right on pretty much w/everone
the fill leval is right 7 qts brings to top but GM says 6.5?? also you may want to get a magnitic drain plug...
Old 09-15-2001, 04:23 AM   #3 (permalink)
IMA Z06,Thanks for your reply.I did add the magnetic drain plug.I am going to do the Zaino treatment today.BTW can you recommend a good place for service in Conn. R.I area? steve.
Oil change % digital readout accurate or should i change at 3000? briann510 C5 Z06 - Pit Road 17 08-28-2005 08:25 AM
Oil Change when you have an Oil Cooler Bob C5 Z06 - Pit Road 5 07-10-2005 01:28 AM
Oil Extraction Units for Oil Change GB_Z06 C5 Z06 - Grandstand 11 10-12-2003 08:42 PM
Oil & Oil Filter Change Intervals gaijin C5 Z06 - Pit Road 0 03-29-2003 08:31 PM
Do you change your oil pan with every oil change? (I do) Big D C5 Z06 - Grandstand 9 10-07-2002 01:53 PM
» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
