So I have searched high and low, but to no avail. What is the size of AN fitting to order from this page:
http://www.pegasusautoracing.com/gro...=BRAKEADAPT3AN
(or different, if that's not the correct link)...
to replace the banjo fittings that came with the Goodridge SS Brake Lines I just received? Or is this possible? I understand I may have 'effed up not going with the Mallett lines which are pre-assembled with AN fittings, however, I don't really want to hassle with returning the lines I have now if there are correct sized replacement fittings available.
Thanks!
~Cory
