Old 05-01-2006, 12:04 AM   #1 (permalink)
fuel pump on 02 z
How hard is it to change the fuel pump on an 02 z? i know you have to pull the fuel tank but i was wondering how hard it is. also does it need to be sumped?
thanks
02 blk z06:
sdpc 402, afr 205s.
michael02z06 is offline   Reply With Quote
Old 05-01-2006, 06:05 AM   #2 (permalink)
Super Moderator
FRC Tom's Avatar
No need to pull tank.
Just pull the heat shield and it's right there.
It is what it is
Old 05-01-2006, 06:33 AM   #3 (permalink)
briann510's Avatar
not related to your 02, but my 03 was at the dealer for 2.5 months trying to replace the fuel pump that burned up (I guess 03's had 2 pumps, 1 in tank and 1 out and this was the in tank one). Anyway, they didnt have a special o-ring seal that only was applicable to the 03's pump and they had to finally tear into another 03 after I was gonna cause trouble cause they had the car almost 3 months and the o-ring wasnt made seperatly. I know they had to tear apart half the rear suspension to get at it they said and drop the tank. When car was deliverted back they forgot to tighten all the rear suspension back and it practically fell out of the car when driving off.
2003 Z06 with A&A Vortech V-2 T-Trim package at 8 psi
briann510 is offline   Reply With Quote
Old 05-01-2006, 02:50 PM   #4 (permalink)
'02 EB/MR Z
80% Track, 20% Driver, 100% Z
Old 05-01-2006, 05:23 PM   #5 (permalink)
have any of you installed an aeromotive fuel pump in your car? where do i get the fuel lines at? i have the fuel tank drained and the cover off. i am trying ot figure out how to pull the tank out if i even need to. i am not sure what to do next.
01 02 fuel pump? bobby778 C5 Z06 - Pit Road 1 11-22-2004 05:02 PM
Fuel Pump Wiring? EFI-1 C5 Z06 - Pit Road 0 09-13-2004 05:39 PM
Can you hear your fuel pump? jub jub C5 Z06 - Pit Road 18 12-22-2003 10:42 AM
'03 Fuel Pump / Fuel System Question BlackZee06 C5 Z06 - Pit Road 9 08-09-2003 10:06 AM
Fuel pump??? Buzz C5 Z06 - Pit Road 0 03-23-2002 10:48 AM
