Thanks for the replies.
I usually start with a full tank, but 3/4 through a day I'm usually down around 1/4. Maybe there is an issue with the traction control?? Usually, I run the traction control in performance mode, but the last two times I had the traction control fully enabled. I'll have to connect a scanner and check for error codes.
