Hi
I did have this problem on a much lower mileage car.
Had the C4C5 specialist fix it for me.
By me it was a bad switch.
Page him and ask him for his input.
David
Hope you found the cable in the back of the drivers side hatch
area. I think its marked "fuel"
called 1-800-chevy and they couldn't tell me, then the dealership said there was a cable in the back. couldn't find it, but did see the release cable in the center-that one must be for the trunk...?
Your secondary fuel door release is just aft of where your partition is on along the drivers side wall. It may be underneath the carpet somewhere.
It is under the carpet a little more forward if you follow the window molding down.. I had to find ours at the last track day But I think our trans guys forgot to hook it back up
thanks everyone-will go out to the vette today and try to find the release!
yeh "tapping" didn't do a thing, even trying to PRY the door open with a screwdriver did nothing. a mechanic ended up getting it open by jimmying the spring while I held the release button down in the center console.
A screwdriver, WOW some mechanic. Every car made that has an electric release for the fuel door has a mechanical release in the trunk area. This is a federal law. I hope no damage was done to your black beauty.
