Old 11-21-2004, 10:43 PM   #1 (permalink)
gear ratio, how much will it help in the 1/4!
Lets say a stock Z06 (1) vs Stock Z06(2). Only difference in both cars is that Z06(1) has changed his ratio.
How much difference will it make in his 1/4 mile time against Z06(2). I'd like to know the difference when Z06(1) has 373s, and the difference if he has the 390s.
thanks,
Ebrahim
MTI stage 2 heads, X1 cam, LG headers, 90mm LSX intake, B&B bullets exhaust system, vararam, air bridge, hurst shifter, Exedy twin disk clutch, tuned by MTI
best E.T 11.78@119 (cam only)
405bhp is offline   Reply With Quote
Old 11-21-2004, 10:54 PM   #2 (permalink)
Super Moderator
FRC Tom's Avatar
390s will get you in the 11s.
Perfect gear for a stock Z06.
It is what it is
Old 11-22-2004, 03:27 PM   #3 (permalink)
I agree with Tom, although there's probably not much actual difference between the 3.73's and the 3.90's in your example as far as acceleration. Obviously if you go from 3.42's, which Z's come with, to 3.90's you'll see a bigger gain.
NewZO6 is offline   Reply With Quote
Old 11-22-2004, 03:43 PM   #4 (permalink)
Kat
Having had the 4.10's now 3.73's I like the 3.73's much better.. I made the best passes of my life with the only change being the 3.73's and I only had 7 cylinders Oh I'm also not stock
Old 11-23-2004, 04:09 PM   #5 (permalink)
When I was near stock with 3.90's I had a more difficult time launching the car at the strip and spun more on the 1-2 shift causing my 1/4 mile times to suffer. Drag radials eliminated this problem. So, on street tires with 3.90's I feel you will have no advantage over stock car.
03 Z06 H/C
9.985@138.80
Best 60' 1.41
Tuning for gear ratio change JMFND C5 Z06 - Tuning & Electronics 2 06-29-2007 03:07 PM
Need help on Gear Ratio N2O4YOU C5 Z06 - Pit Road 16 02-07-2006 10:39 AM
Motive Gear 3.73 Gear Ratio Shortage Dynotech Eng. C5 Z06 - Pit Road 4 02-18-2005 08:48 AM
Transmission - 5 Gear Ratio Change?? VAI C5 Z06 - Pit Road 10 07-20-2004 07:07 AM
4.10 gear ratio? 405bhp C5 Z06 - Pit Road 11 04-18-2004 11:56 AM
