Old 04-02-2004, 09:45 AM   #1 (permalink)
gears
whats the best gear to go with 3:73 or 3:90
vcav is offline   Reply With Quote
Old 04-02-2004, 11:23 AM   #2 (permalink)
For what engine, what mods, T1 or drags?
Number 5 needs more input!
z62jag is offline   Reply With Quote
Old 04-02-2004, 11:38 AM   #3 (permalink)
For a Z06 which has the MN12 Tranny, the best gear is 3.90 IMO. 3.73 are a close second and 4.10's are to short for the Z06. 4.10's are great for the MN6 tranny.
Old 04-02-2004, 01:22 PM   #4 (permalink)
Will the speedo be off a small amount and if so can it be corrected using ls1edit?
Thanks
Old 04-02-2004, 05:41 PM   #5 (permalink)
As long as you dont change tire size (height), you do not need to worry about the speedo.
2002 Z06 Black/Black, fully optioned. Built 3-25-02, delivered 4-30-02. Chrome Z06 wheels/GHL Exhaust/Donaldson Blackwing/CAGS/Frame Savers/CLB/Rocker Panel protectors
WWK888 is offline   Reply With Quote
Old 04-02-2004, 06:03 PM   #6 (permalink)
I think the stock rear is 3.42:1 gearing. If you change out to 3.90 gears I believe the speedo will be off about 12%, or show 100 mph when you are really only going 88 mph.
03 EB Z is offline   Reply With Quote
Old 04-02-2004, 06:06 PM   #7 (permalink)
Get the 3.90's!....and your speedo wil not be off at all..
Wash
tr...motorsport 18" on all 4's...bfg kd's
kirbin shifter.mgw pistol grip.lowered all the way. .160 thermostat.Vortex intake.euro tailights.euro head lights.3m paint protection.random high flow cats/xpipe.Tubi catback exhaust..Textralia oz700 clutch, DTE diff with 3.90's
and a lil bit of cubic inches
washguy is offline   Reply With Quote
Old 04-02-2004, 06:07 PM   #8 (permalink)
Wrong information my friend...
Old 04-02-2004, 06:17 PM   #9 (permalink)
If the speedo is reading the final output rpm of the axle and tire size doesn't change, you are correct!
Old 04-02-2004, 10:26 PM   #10 (permalink)
im confused now... if you change the gears do you need a speedo correction or not?
Old 04-02-2004, 10:33 PM   #11 (permalink)
NO....you dont............ Wash
Old 04-03-2004, 06:19 AM   #12 (permalink)
Thanks
C5s speed is measured by the rotation of the output shaft. LS1 Edit Menu specifically says recal is not required when changing gear ratios. However, it is required when changing tire size.
Gears....AGAIN GR8 WHITE C5 Z06 - Pit Road 6 09-19-2005 11:20 PM
Gears: To be or not to be? Cajundude C5 Z06 - Pit Road 0 12-16-2004 02:49 PM
Gears: 3.73, 3.90, 4.10? GR8 WHITE C5 Z06 - Pit Road 3 09-26-2004 12:57 PM
3:90 Gears? bumble bee The Garage 1 10-05-2003 09:14 AM
4.10 gears AJFZ06 C5 Z06 - Pit Road 42 11-17-2002 07:45 PM
