Closed Thread
Old 02-15-2005, 11:07 AM   #1 (permalink)
DJWorm's Avatar
General Torque Specs
Brake Caliper Guide Pin Bolt / 23 Ft#
Brake Caliper Inlet Fitting / 37 Ft#
Brake Caliper Bleed Screw / 106 INCH #
Front/Rear Brake Caliper Bracket Bolt / 125 Ft#
Exhaust H Pipe to Overaxle / 37 Ft# *
Exhaust H Pipe Hanger Bolt / 37 Ft# *
Exhaust Hanger Bolts / 37 Ft# *
Exhaust Pipe Clamp Bolts / 37 Ft# *
Exhaust Manifold (first pass) / 11 Ft# *
Exhaust Manifold (final pass) / 18 Ft#*
Exhaust Header Bolts = Follow Manuf. Recommendation*
*All Header and Exhaust fasteners should be rechecked after 2-3 heat cycles or 1 week
Front Spring Retainer Bolts / 46 Ft#
Front Shock Lower Mounting Bolt / 21 Ft#
Front Shock Upper Nut / 19 Ft#
Front Sway Bar Clamp Bolts / 40 Ft#
Front Sway Bar End Link Nuts / 53 Ft#
Rear Spring Retainer Bolts / 46 Ft#
Rear Shock Lower Mount Bolt / 162 Ft#
Rear Shock Upper Mount Nut / 22 Ft#
Rear Sway Bar Clamp LOWER Bolt / 70 Ft#
Rear Sway Bar Clamp UPPER Bolt / 49 Ft#
Rear Sway Bar End Link Nuts / 53 Ft#
Shifter Base to Torque Tube Nuts / 22 Ft#
Shifter Insulator to Body Nuts / 106 Ft#
Wheel Lug Nuts (3 step) = 30/60/90 Ft# * ** ***
Wheel Lug Nuts (1 step) = 100 Ft# * ** ***
*ALWAYS use a "STAR" Pattern
** ALWAYS double check
*** ALWAYS check "HOT" for racing conditions
AMSOIL Online Store
DJWorm is offline
Closed Thread
LS1/LS6/LS2/LS7 General Engine Specs DJWorm C5 Z06 - Pit Road 0 02-15-2005 05:34 PM
Tranny/Diff/Cooling Specs & Capacities + Torque Specs DJWorm C5 Z06 - Pit Road 0 02-15-2005 11:52 AM
Torque specs? quicksilvr C5 Z06 - Pit Road 3 09-19-2004 04:05 PM
Need some torque specs. jknight C5 Z06 - Pit Road 2 07-22-2002 07:42 AM
What is the Torque specs? 01BlackZ06 C5 Z06 - Pit Road 4 03-23-2001 10:02 PM
