Old 01-20-2004, 06:54 PM   #1 (permalink)
Got a couple questions.
Here goes.
When I got my Z it had 55 miles on it..nice retired guy delivered it from San Jose.
The idle was a little rough felt like it was cold even when it was warmed up. You also had to really feather the clutch to get a smooth start out of first.
At about 550 miles I got a Halltech Trap.(very nice unit by the way) Installed it,did the relearn and ever since idle is much smoother.The clutch release is way smoother.
I realize the reason the clutch is smoother is because of the way the motor is running.
These things changed with the trap.I have 900 miles on her now.
Never had a code thrown. It pulls like a freaking freight car after 3500 rpm. Especially in 2nd and 3rd.Mostly because I don't have
enough road around here to test 4th 5th 6th
My question is this I have done much reading on this forum about air intake installs.Without a edit they run too rich even read you may loose torque without a edit? If its not throwing any codes am I within safe perimeters for the motor even if it is too rich.Also does the edit just for fuel trim void your warranty?
I appreciate any info you are willing to share.Thanx
Jeff
GearGrinder is offline   Reply With Quote
Old 01-20-2004, 07:05 PM   #2 (permalink)
I think technically the edit will void warranty. Find a good dealer that will work with you. I took mine in for some warranty work a few months ago and they never said a word about the mods. If the car isn't throwing codes...then everything is ok. The parameters are pretty narrow for the ECM. I would much rather run rich than lean.
Si vis pacem, para bellum.
Old 01-20-2004, 09:06 PM   #3 (permalink)
Thanks for your reply Case..
Old 01-20-2004, 09:13 PM   #4 (permalink)
No problem...I'm just glad you found the website and are enjoying the car.
Old 01-20-2004, 09:31 PM   #5 (permalink)
Looking at a z-16 a couple questions .. 99CORVETTEGUY C5 Z06 - Grandstand 15 09-28-2006 08:54 AM
New Owner/Couple Questions Yellow Streak C5 Z06 - Grandstand 43 02-01-2004 06:50 PM
A couple of Z06 Questions RS2600 C5 Z06 - Grandstand 3 09-25-2003 05:21 PM
Just Installed my T1-C, A couple of questions... mdickie C5 Z06 - Pit Road 3 04-25-2002 09:15 AM
couple questions Z061 C5 Z06 - Grandstand 4 04-09-2001 09:13 PM
