hey guys, pulled into the garage about 5 minutes ago. killed it, opened the door and turned the headlights off and I hear the most annoying sound heard to man. anybody know what's going on?
I had the same thing happen to me recently….sounds like a dying crow under the hood. Had my wife cycling them up and down as I carefully put a few shots of WD-40 onto various parts of the lifting mechanism. The squeak finally stopped when I got to the upper hinge (closest to the top of the headlight) almost right between the headlight and the painted fiberglass cover. I could only get to this spot from the back of the headlight with the hood open.
Geoff
02’ QS
yep, its my driver's side also. I will try the WD-40 approach and if that doesn't work, I guess I will have to make the 1st trip to the dealer . Thanks for all of the help guys.
Just happened to me a couple days ago. I think it's the bitter cold out here. Not too worried about it. Had to take her out for a ride. It was actually dry with clear roads for once.
Just went back in to the garage to try the WD-40 thing. Opened my door turned on the headlights. Squeak. Turned the headlights off. Popped the hood, turned the headlights on. No Squeak Weird
