Help with Alignment Specs?
Just got the shop manual for my 2002 Z06. I'm looking on page 3-20 at the alignment specs. Sadly, they don't put units on any of the measurements, so I'm wondering whether the toe is expressed in inches or degrees. Or maybe something ELSE. Looks like degrees, but that makes the toe so close to zero as to be barely measurable.
I've been advised by another autocrosser to use 1/4" toe-in at the back and zero at the front, but that seems WAY far away from the specs in the rear. I'm more surprised at the specs than at my friend's numbers, but I want to understand the situation before I go cranking.
Thanks for any help...
jim
2002 Millennnium Yellow Z06
1992 white Spec Miata race car, for quick cornering
