The T1 Parts are listed in the back portion of the Chevy Hi Performance Book from your Chevy Dealer.
You can purchase as a kit or seperatly.
There are springs F/R, Brake Discs, Camber Plates, Shocks, Sway Bars etc.
These were basicly put together by Chevy to up grade a C5 to racing status.
Some of the Z06 stock parts may already be adequat for racing, such as the sway bars, springs, shocks or you may want to change them.
I originally wanted to set my car up for auto cross and decided to up grade the "weakest link" on the Z06, the brake rotors. Although not allowed in the stock class I ordered the rotors mentioned under special part numbers in T1 thinking the would be better. What I got from Chevy was another set of Z06 rotors. It appears that Chevy has used some T1 parts already on the Z06. I tried to find this out before hand ie. I made inquiries as to which were better the Z06 parts or the T1 parts but found no answers. I would as a very minimum order the camber plates however. and start there to set up and sort the car.
BTW Dave Farmer "Y2K Hardtop" on this board is active in T1 and will be glad to help you.
Chuck Mallett at Mallett Cars, LTD. can also be very helpful. His shop is in Berea, Ohio.
www.mallettcars.com
One further point, and not to disuade you in any way. The T1 drivers mean buisness. They are out to win. Even though they are driving basically stock cars the driving is competitive ie they will bump and rub even shunt you off course if necessary. Think about it.
