Old 06-23-2005, 06:54 PM   #1 (permalink)
Send a message via AIM to 427l
Help with Selecting New Tires
I'm currently debating the following tire selection.
F1 Supercar 265/40/17 - 295/35/18
BFG G-Force 275/40/17 - 295/35/18
Michelin Pilot Sport 265/40/17 - 315/30/18
Any ideas which tire would give me the best all around grip on the road? I've heard a lot about the G-Force but I'm wondering if the wider Michelin would be better. I'm thinking I don't really need the 275 in front since the car is oversteer happy as it is. Not at the point yet where I'm buying just drag radials or just hoosiers for autocross so I'm looking for the set the "does it all?"
Any idea on how the wear compares?
427L
427l is offline   Reply With Quote
Old 06-23-2005, 07:20 PM   #2 (permalink)
I was pretty happy with the Michelin Pilot Sports. I just started running a Pirelli in the rear but the Michelin is a good tire overall IMO. Good Luck!
'03 Z06 447 c.i. N/A Built by ECS
600+ RWHP 600+ RWTQ
The fastest MPH N/A Z06 in the USA! Courtesy of ECS
Antivenom 447 is offline   Reply With Quote
Old 06-23-2005, 07:29 PM   #3 (permalink)
FiveOJoe's Avatar
Michelin is having a big sale on nearly new tires in the Indianapolis area.
sig by nutbush
Old 06-23-2005, 07:31 PM   #4 (permalink)
spdrcrj's Avatar
Have you checked into the Nitto 555RII's or Toyo Proxy T1-RA's (I think). They are good "all around" tires but wont last you as long as the tires you mentioned. I have a set of RII's on the rear and Im guessing their wear time to be about 8k miles. That is without any autocrosses or DE's, just some occasional "spirited" driving.
Jim
Old 06-23-2005, 10:09 PM   #5 (permalink)
I think the BFG KD is better than the GY F1. The F1 is an GM OEM compromise tire. I ran the GY at a few DE's and thought they were a bit scary. The KD will give you a lot more confidence seat of pants. They almost feel like R-compound tire when new. My KD's were really spooky when they were down below the wear bars in the rain... but maybe the GY or any tire would hydroplane with virtually no tread. I switched back and forth several times last year between events. The KD is king on dry pavement.
The Pilots have always been good tires. The old MXX Pilots were the equal of the KD, but the new Pilot Sports are biased a little more to wet weather. Take a look at the outside tread blocks. Big blocks with no sipes is a better dry tire all things being equal.
The GY seem to wear fast for some and not for others. IMHO GY tires seem to harden up rapidly, so if you don't wear them out right away, they will last forever. The KD's usually would be competitive in AX for almost two seasons. I usually ran them for 2 1/2 -3 years which is maybe 12,000 miles and 20 DE events and as many Solo II type events.
Dunno anything about Nitto & Toyo. The only guy who outruns me on street tires at timetrials events currently has MPS tires. I suspect he is just a better driver.
I hope this helps
Old 06-23-2005, 10:41 PM   #6 (permalink)
I prefer the GYs over the KDs. I would stay away from the Pilot Sports. If I were you, I'd get the Michelin PS2s. The Pilot Sports (first generation) are a step down from the GYs (what I've heard).
GYs are a good all-around tire.
PS2s are supposed to be a little better than the stock GYs.
KDs, sorry, I would pass on those.
Good luck,
Alex
Old 06-23-2005, 10:43 PM   #7 (permalink)
Yeah thanks, that was just the type of info I was looking for.
Old 06-23-2005, 11:54 PM   #8 (permalink)
Have you considered KUMHO or Firestone?
Tony
TZ06
Tony Skarbic is offline   Reply With Quote
Old 06-24-2005, 09:08 AM   #9 (permalink)
I have the firestone wideovals. I just got them installed about 1 month ago, i have done around 1400miles on them already, and I find them to be a very good street tire. I drove in rain storms with confidence. and ... they are pretty quiet on the hwy, all around I am very satisfied.
I can't really compare them to any other tire, when I got my Z, the stock Goodyears were completely bald. I didn't have any traction, even 3rd gear shift would spin. Now with the wideovals, as soon as I shift to 2nd gear, I get 100% traction, and I was pretty surprised how well they grip, and they don't squeal on the curves.
anyway, i don't do any autocrossing or road racing, i just drive on the street, and I am very happy with them, and I believe they are the most inexpensive tires on the market, i think they sell for around $600 on tirerack.
mannygmt2 is offline   Reply With Quote
Old 06-24-2005, 11:17 AM   #10 (permalink)
BLEUBYU's Avatar
I have had the PS2's on for about two months now, and they are better than the F1s in just about every aspect. The tires themselves are also a few pounds lighter than the F1s they replaced- yielding very desireable reductions in unsprung weight. I don't know exactly what happened at Indy last week, but the Michelin PS2s are a lot closer to the rubber that the wining C5R and C6Rs run than they are to Formula One tires.
BLEUBYU is offline   Reply With Quote
Old 06-24-2005, 11:55 AM   #11 (permalink)
PS-2 Michelin are very good, grip, ware and lots of $$$, (good all around tire for a daily driver). Should last a long time. Nitto 555 RII are sticky but burn down pretty fast. If you drive just on the weekends they will last for a while. Lots of tires for mild to wild money and purpose. It depends on what you want to do with your car.
D.J.
2007 Silver Z06
2000 Coupe
Old 06-24-2005, 12:08 PM   #12 (permalink)
Old 06-24-2005, 03:09 PM   #13 (permalink)
bud miller's Avatar
IMO-depends on you modifications-if your basically stock -i replaced with F1's again and i am happy with them-weight, traction overall..i think i would have gone with the nittos,but i do think the way i drive -they would probably only last about 12K on the rears...which makes them sorta "pricey", but the last 5K mi on my F1's seem to be worthless on traction..
good luck
i feel i gained back about a 20 hp loss in traction , just having new tires on the rear..
01 QS, Z16 wheels.ported exhaust manifolds,02-4 intermediate pipes,partiton.side screens,k&n,mod airbridge/coupler,tune.383rwhp 372tq Nitto R2's
bud miller
bud miller is offline   Reply With Quote
Old 06-24-2005, 03:42 PM   #14 (permalink)
About 2 months ago I installed Toyo T-1s on the front. Very quiet and smooth and suppose to be awesome in the wet. My local Firestone dealer got them for me for less than me buying on the Web and having them shipped to my home. I looked at the Firestone Wide Ovals, but am wary after having been bitten by them back in the 70's with their 500's--and if you check the Web, there are still all kinds of horror stories today.
Melsy
'03 Red/Mod Red
Melsy is offline   Reply With Quote
Old 06-24-2005, 09:24 PM   #15 (permalink)
Send a message via AIM to insert_car
i've owned pilot sports, s03's, and KDW2's. and hands down the KDW2's are the best tires i have owned. unbelievable grip for a street tire. i AUTO X, DRAG, and ROAD RACE.
BFG KDW2'S get my vote
01 Corvette Z06 - Millennuim Yellow
BP LT Headers / Corsa Catback / Volant CAI / Hurst SS
insert_car is offline   Reply With Quote
Need help selecting a new clutch GNX Guy C5 Z06 - Pit Road 16 01-19-2006 01:04 PM
Need some help selecting new rotors... JUICE C5 Z06 - Pit Road 11 12-26-2005 03:12 PM
WTT: Brand new 18x10 18x12 CCW street wheels w/tires for HRE's w/ tires ownedya Member Sales - Parts & Cars 12 06-18-2004 11:58 AM
Need a little help selecting tires for the strip cyaford Racing 3 02-13-2003 01:23 PM
need help with selecting a new air intake fabelodds C5 Z06 - Pit Road 7 09-22-2002 04:31 PM
