Does anyone know the good, bad, or no difference in running at high RPM, near or at limiter with the AC on. I'm sure there would be some performance difference but is there harm to the compressor. This is something that can and has happened while "protecting turf"
Originally posted by 70boss302 And I thought it was the adrenaline rush that was making me sweat at high speeds when the whole time it was the AC kicking off!! Bill
You know this forum just never ceases to amaze me. I continue to expand my hat size with all of this info. Thanks again guys and gals.
Happy Birthday.
Best Run 12.43@115.2 Best 60' 2.03
Borla Stingers, Vararam, Vinci fan controller, 178', Hurst w/Delrin Hardbar, chromies, lowered 2", frame savers, rocker panels, tinted, partition, billet antenna, Lloyd's mats and Zaino.
It should happen at Wide Open Throttle and is independent of the RPM.
Eric Wong
04 Carbon Metallic Yukon Denali ARRIVED
#199 BMWCCA IP Cosmos Black BMW M3
01 Magnetic Red Coupe SOLD 12.4@116MPH
2002 DC SCCA Region SM2 Champion Our Autocross Team
Originally posted by gmblack3 Yes this is true. If you run at a road coarse leave the A/C on at all times, it will keep both fans on and your water temp will stay nice all day.
I wouldn't do this if I were you!! Had a friend who (unintentionally) left his A/C on while on a road course track day (I was his passenger). The compressor does in fact cut out at full throttle or even 5K rpm or whatever....BUT, coming into corners and slower parts of the course the rpm drop and your out of the throttle causing the A/C to come on. The A/C comes on at typically high(er) rpm forcing the clutches to have to catch up with engine rpm. When our 20 minute session was over, we pulled into the pits with smoke coming from under the hood....the A/C compressor clutches had fried.
This was in a '96 LT4 car and unless the A/C compressor has been redesigned, I suggest driving with the windows open and go like hell to keep airflow going through the radiator.
HarryB
2002 MY Z06
1996 Grand Sport #676
1995 Indy Pace Car
1990 ZR-1 #2169 (Gone but not forgotten)
