My father and I came up with an idea the other day. I'm looking to get a switch that will disable all lights on the rear of the car...for the purpose of a movie i'm looking to make.
I would want a small switch in the car that upon activation would kill the plate and rear lights. And possibly kill the side markers. Pretty much anything other than the headlights.
Is this doable? What would be the best way to go about this?
FYI: I've never run from the cops in my life. If you have something negative to say about this idea keep it to yourself. I'm looking to do this on the all black Z we'll be getting in December.
06 Z06 Black/Black/Black/Black 1LZ-U3U-RC8 Mods: Exhaust switch - Bondurant Driving School - 345 Pilot Sports - Vette Doctors Air Charger - Tune =489rwhp 461rwtq 11.240 @ 128.5 w/ terrible 1.856 60' --- 03 Z06-EB/ModRed..traded in. Others:96 Grand Sport coupe #451-71 Vega 900hp 1800lbs
The easiest way would be to run all the grounds for those lights through a switch.
The Emergency flashers/ABS/TC use a ground circuit thru the brake light bulbs. It puts 5-volts thru them when the engine is running and the brakes are off. If you cut the ground it will disable those systems and could burn out the EBCM.
You can disable *all* the external lights by not using the running lamps and pulling the fuse for the DRLs. Then, your only problem would be turn signals and brake lights. You can avoid the turn signal problem by not using the turn signals, so your only problem would be brake lights.
Since you don't intend to break the law, you must not be planning on running this project on public streets. If so, you could address the brake light problem by pulling the fuse for that circuit.
Going to the trouble of modifying the wiring to do what you want to do seems extreme for a photo shoot. Adding a switch is a more permanent change, that would only be worth it if you intended to do this all the time. You don't intend that, though, do you?
I have to say that back in the day when I was a street badboy I could do that on my 68 Chevelle. One night when going a little, no a lot too fast, and the wrong person started to catch up. Well lets just say I fliped the switch and put the petal to the metal. Warp drive saved me. Of course
I would (and I really mean it) not do something as stupid again. It just isn't worth the risk, penalty, or danger. You just just triggered an old story from the olden days. You could run a hardwire switch to the tail lights, but keep something in mind. Set it up so that you have to defeat the tail lights everytime you start the car. You don't want to turn them off and forget about it, or ever be in doubt as to whether they are on or off.
Keep the switch low key as I have doubts as to it's legality. Good luck.
In the connector industry, it's called a 'terminator', just like the CAGS defeat. Something to terminate the circuit so the system is loaded properly but without the light.
The circuit probably doesn't require a load, but simply continuity of ground provided by the bulb casing, otherwise a burned out bulb would result in loss of ABS, etc.
