Will go over all you said... I dont even FEEL the misfire, the scan tool said it happened at 6500 rpms at 99.9% wide open throttle... so I presumed it was the limiter. The plugs and wires are both new and we took the plugs out when installing the headers. The coil packs were flipped up over the intake. I know this will be hard to find, but it will be a long winter..
What is odd is that it started AFTER the header install.
