Old 05-06-2005, 04:00 PM   #1 (permalink)
iPod install
Hey
I just got an ipod and I was trying to wire it up today. I ordered the GM CD changer harness, and a "neo ion" from mp3yourcar. Today I wired it all up per the pictures/instructions on this thread, however I cant get the thing to work. I press the aux button, but nothing happens. Is there something I am sorely missing? The iPod is powered up when I attempt to press the aux button. Do you think the "neo ion" could be bad? I am very frustrated, and would apreciate any and all help.
Thanks!!
2002 Black/Black Z06. SOLD
ChaseN is offline   Reply With Quote
Old 05-06-2005, 04:20 PM   #2 (permalink)
Send a message via AIM to Nabbs Send a message via MSN to Nabbs
You need to set the dip switches correctly. Unplug the unit, set the dip switches correctly, and then plug back in. Your instructions should have the appropriate settings for the switches.
-N
Current: 2006 C6 Z 2LZ
Previous: 2003 C5 Z06
DD: 2008 Jeep SRT8 All options
"I only street race in school zones, at 3PM, on Mondays"
Nabbs is offline   Reply With Quote
Old 05-06-2005, 06:05 PM   #3 (permalink)
Already done I first hooked it up without setting the DIP switches, but i later realized my error, unplugged the unit, set them, and plugged it all back in. Unfortunately, still no luck. Any other ideas to what I could be missing?
Edit: My manual says to set the #3 and #8 DIP switches on. Anyone else that could cross reference this?
Old 05-06-2005, 07:01 PM   #4 (permalink)
I have this setup but i have an alpine deck and adapter.
U might wanna check out sound domain.
600hpIsntEnough is offline   Reply With Quote
Old 05-06-2005, 09:46 PM   #5 (permalink)
I am 100% sure this is the problem. I am running the iPac which appears to be the same unit as yours with the cd changer cable and the factory head unit. Apparently the instructions are not clear at all in regards to the Dip switch settings. You may want to unplug, turn #3 off, and then re-try. I had the same issue and ended up trying one other dip switch combo setting, and it worked. This is why I mentioned the Dip switch settings. If you still can't get it to work tomorrow, I will go and check the settings on my car and report back.
However, I distincly remember that there was one Dip switch setting that eronously labeled in the manual. The manual stated something to the effect that 99-04 cars were to be on and cars without the cd changer cable (or something to the effect) were to be off.
-N
Old 05-06-2005, 09:50 PM   #6 (permalink)
I have my instructions at the office -- will check. Mine started right up. I believe if you had it set-up wrong, you may have to disconnect it from the car power to clear the memory. Try that.
03 Zo6, Black, Mod Red Interior
03 Ultra Classic Anniversary, Silver/Black
04 Escalade Black/Slate
reproman is offline   Reply With Quote
Old 05-06-2005, 10:00 PM   #7 (permalink)
OK, saw that you had disconnected the power. And just found the manual. I would still disconnect the module, set all the dip switches off. Then according to the instructions, it states that "settings for e&c" are "3" and "8" ON.
How are the two connectors at the passenger well? Perhaps they are not pushed in all the way? The one plug is easier to guide with a flat blade screwdriver and your finger. Just bend the wires 180 degrees to the connector and work it in the socket.
Or worse case, the module is defective.
Old 05-06-2005, 10:05 PM   #8 (permalink)
And lastly, make sure the Ipod is playing and try stepping the controls on the radio to make sure your in the "changer mode." I would eject the CD, and make sure the readout has two sets of numbers like 1 999 -- I guess this corresponds to CD number and track. The system is slow to respond so just after pushing a button, wait and see what the response is.
Old 05-07-2005, 10:44 AM   #9 (permalink)
I am having absolutely no luck with this thing I tried all the suggestions on this thread (unplugged, turned #3 OFF, ejected CD, pressed button and waited) and it still won't work. I am going to call customer service monday and see if they can help me out, and if I still have no luck, I'll exchange the module. Of course, in the mean time, I'd love to hear anyone with suggestions.
Thanks all!
Old 05-07-2005, 11:24 AM   #10 (permalink)
Does the iPod even charge? Does your PC detect yoru iPod -- if not, have you tried resetting your iPod?
Are you sure you plugged the correct harnesses into the cd-changer harness? The two connectors for the cd-changer cable are located on the right side of the footwell.
-N
Old 05-07-2005, 11:40 AM   #11 (permalink)
I just got my neo ion too. Havent installed it yet, but just curious as to where you mounted your ipod?
DeNguyen is offline   Reply With Quote
Old 05-07-2005, 12:15 PM   #12 (permalink)
Send a message via AIM to Blue2002Z06 Send a message via Yahoo to Blue2002Z06
i agree, i have the alpine CDA-9833 head unit and KCA-420i ipod adapter, absolutely love the combination.
it sounds like you have a faulty adapter id see if the company you bought it from will let you return it for a new one.
Dave
2002 Electron Blue Z06 (sold 1/18/06 )
2006 Daytona Sunset Orange Metallic Z51
Vararam Snake Charmer, B&B Bullets....few others on their way.
Blue2002Z06 is offline   Reply With Quote
Old 05-07-2005, 04:57 PM   #13 (permalink)
Send a message via MSN to rutiger
are you sure you did the wiring correctly? i used the ab-gm10 harness and followed these instructions: http://www.pac-audio.com/bulletins/corvette%20mod.pdf.
if you're sure the wiring is correct maybe you do have a defective unit.
03 Z06 579rwhp/469rwtq
06 Jeep SRT8
06 Magnum SRT8
rutiger is offline   Reply With Quote
Old 05-07-2005, 05:00 PM   #14 (permalink)
here's where i placed my ipod. i put the ipod interface unit behind the black plastic in the passenger footwell.
Old 05-07-2005, 05:11 PM   #15 (permalink)
I put mine in the console -- ran the white cable from the converter box mounted on the upper right of the passenger foot well.
I removed the cigarette lighter, and Dremeled a channel at the bottom so that the cable can pass right through. Reinstalled the lighter socket and it all looks OEM. The slack can also be stored under the console and pulled out as needed. Makes it handy at stoplights to review the music lists. And the Ipod is not showing to those who may want it.
Ipod Install.... HELP Chrisrokc C5 Z06 - Pit Road 0 10-14-2005 06:04 PM
FS: Ipod Interface DeNguyen Member Sales - Parts & Cars 4 10-12-2005 01:41 PM
ipod silverbullet04 The Garage 3 07-21-2005 01:11 PM
iPod help? exSSer The Garage 0 12-27-2004 04:57 PM
Need help with iPod install... S-TEE C5 Z06 - Pit Road 4 10-06-2003 02:42 PM
