Old 08-28-2003, 06:28 PM   #1 (permalink)
Torched's Avatar
Just Installed CAGS Have Question
Had to get rid of that annoying 1st to 4th skip shift.The car now with CAGS installed does not do the annoying skip shift any more but the idiot light still comes on. Is this how it's suppose to work? Greg
02 Z06 Torch Red/ Ebony AAB,DD0,B84,V49
Built 9-24-01, Number 7,896 02 Vette Off The Trim Line, 08 Z06 Jetstream Blue Metallic/Ebony
100% Satisfied Rick Daniel Customer! *NCM Individual Member #9781
Torched is offline   Reply With Quote
Old 08-28-2003, 06:32 PM   #2 (permalink)
Greg,
From what I have read the light continues to come on. Just ignore it.
Si vis pacem, para bellum.
Old 08-28-2003, 06:45 PM   #3 (permalink)
Z06 WinterFest Coordinator
Kens06's Avatar
Location: Gilbert, AZ Z06 Fest II,III,IV,V WinterFest 1&2
Send a message via AIM to Kens06
You didn't install CAGS, the doggle you installed interupts the signal to the solenoid that activates the gate for the 1st to 4th shift. That means it's bypassed! Yes, unless you do and LS1 edit or other PCM rewrite the light will still come on.
Ken
Kens06 is offline   Reply With Quote
Old 08-28-2003, 06:48 PM   #4 (permalink)
Torched,
Case is right. If you installed a CAGS defeat that plugs into the wiring harness connecting to the transmission, then the solenoid in the trans is no longer powered and will not block you from shifting into second gear, but the PCM will still illuminate that stupid "shift 1 to 4" light on the dash. The only way that I know of to eliminate both the light and the solenoid, is to use LS1-edit software and modify the PCM. I heard that this software costs about $500. Unless you are looking to mod other performance functions, this is an expense way to just turn off the light.Take it for a ride, enjoy the one to two shift, ingore the dash light, and have a Coors light!
03 EB Z is offline   Reply With Quote
Old 08-28-2003, 06:59 PM   #5 (permalink)
Torched's Avatar
Originally posted by 03 EB Z
Torched,
Case is right. If you installed a CAGS defeat that plugs into the wiring harness connecting to the transmission, then the solenoid in the trans is no longer powered and will not block you from shifting into second gear, but the PCM will still illuminate the "shift 1 to 4" light on the dash. The only way that I know of to eliminate the light and the solenoid, is to use LS1-edit sotware and modify the PCM. I heard that this software costs about $500. Unless you are looking to mod other performance functions, this is an expense way to just turn off the light.
Yes i installed the CAGS defeat the plugs into the transmission.The part was like $18.00 from Ecklers.The light dosen't bug me I was wondering if the install was correct and is working as supposed to.Greg
Old 08-28-2003, 07:11 PM   #6 (permalink)
That's weird.. I don't seem to recall seeing the light after I installed the CAGS defeat. Maybe I just blocked it out? I couldn't tell you if I still have it now though because I recently had my car edited.
Bob
Old 08-28-2003, 07:19 PM   #7 (permalink)
If the "1 to 4" light is on, but you are in second, your install is all good
Old 08-28-2003, 08:27 PM   #8 (permalink)
ChuckChurch's Avatar
Send a message via AIM to ChuckChurch
You mean the 1-4 shift light, or the check engine light? The shift light is normal, but a check engine light would indicate the PCM isn't seeing the right resistance from the cags defeat harness.
Chuck Church
2002 Blk/Blk Z06 - K&N, 'uncovered' airbox, LS1-Edit tuning, DIY 185 Thermostat, BPP shifter. 372 RWHP, 358 RW Torque pre LS1 Edit
ChuckChurch is offline   Reply With Quote
Old 08-28-2003, 08:31 PM   #9 (permalink)
On the F-bodies, if you purchase the !cags from SLP, you don't get the light. If you purchase the !cags from other vendors, you do. I dunno...
minivette is offline   Reply With Quote
Old 08-28-2003, 08:33 PM   #10 (permalink)
GotZ06?'s Avatar
Just installed the cags bypass on mine today also. Also found an oily diff. Talked to c4c5 today, he thinks it might be a diff. over fill problem, as there were no apparent leaks that we could see nor any oil "washed" areas on the diff. The oil level in the diff. was full when we checked it. I hope he is right.
I have also noticed that my cags (before I did the bypass) was not very consistant-some times it would come on and some times not?? I hope this is not an indication of a computer problem!!
I tie wrapped the harness to another harness on the trans. instead of the tubing on the body as I don't like the drive line componets being tied to the body.
2003 MY/Mod Red Z06
NCM Member #19159
NCM Delivery # 569-2638 on 3/26/03
http://www.z06vette.com/gallery/index.php?n=365
GotZ06? is offline   Reply With Quote
Old 08-28-2003, 10:14 PM   #11 (permalink)
I bought my CAGS defeat at Xtreme Motorsports for $20. I was expecting the 1-4 shift light to come on even though the CAGS was bypassed, but I never noticed it coming on. Then again.. Last time I was at the track, I didn't even notice the low fuel warning lights until my car was sputtering. I said.. Wait a minute... I wasn't revving that high to hit the rev limiter. I would go check to see if my shift light comes on, but I just had the car edited, so I wouldn't be able to tell.
Bob
Old 08-28-2003, 10:24 PM   #12 (permalink)
Russ; I don't know if this might be your situation or not but if a person usually shifts at or just above the point of engagement for CAGS it would certainly give the impression of sometimes working and sometimes not.
The 1-4 shift indicator should still lite even with CAGS disabled unless defeated with LSEdit.
Pat
02 EB/Mod Red, LPE C5R 427 Twin Turbo, Kirban/Delrin, Brembo, HRE, 665 rwhp, 702 rwtq without variable boost.
Mufflerbearing is offline   Reply With Quote
Old 08-28-2003, 11:21 PM   #13 (permalink)
Send a message via Yahoo to Shootaclay
I just installed my CAGS eliminator a few days ago. Got it from Ecklers. The light will still come on, but only after the engine comes up to temperature. Ignore the light and enjoy.
Shootaclay is offline   Reply With Quote
Old 08-28-2003, 11:51 PM   #14 (permalink)
That's weird.. I swear that my light never came on again. Does anyone else have the CAGS eliminator from Xtreme Motorsports? If so, does your 1-4 shift light come on?
Bob
Old 08-29-2003, 01:11 AM   #15 (permalink)
Send a message via AIM to Birddog-Singer
The instructions for mine told me to expect the light to come on, but assured the CAGS was bypassed. Mine is a plug in piece.
NCM Member# 23402
I "HAD" a 2003 Z with aTwin-cone intake*Air Bridge*Silicone couplers*acrylic intake plate*Coolant Bypass*CAGS*SLP Headers*X-Pipe*7000 Kel Zenon HID Headlamps * Sequential flashing taillights *XM Radio*
Birddog-Singer is offline   Reply With Quote
CAGS question navyasw02 C6 Z06 - Pit Road 6 06-11-2006 09:19 PM
!CAGS Question Vrrooom C5 Z06 - Pit Road 5 10-12-2004 03:48 PM
Quick CAGS Question ZeeOhSix C5 Z06 - Pit Road 5 06-20-2003 09:21 AM
CAGS defeat question NYCHASM C5 Z06 - Grandstand 27 02-27-2002 08:07 PM
CAGS installed z06175mph C5 Z06 - Grandstand 7 02-24-2002 07:11 PM
