Largest rear tires on C5 Z - Z06Vette.com - Corvette Z06 Forum
Old 04-08-2012, 09:31 AM   #1 (permalink)
After searching and reading through the various posts here, I just want to make certain that 315/30/18 is the largest rear tire for a C5 Z06 with stock rims.
Also, want to make sure that there is no cutting of brake ducts and spacers required.
Any input is appreciated!
Cheers,
Jim
01 QS/ModRed, Lingenfelter H/C, B&B 2-tip Bullet, Headers, hi-flow cats, x-pipe, Hurst, Vararam, DTE Stage II Diff with 3.90 gears, RSG Son of Transzilla transmission, DTE Diff Strut - 433RWHP/395RWTQ - and I DRIVE IT as MUCH AS POSSIBLE! 121K+ miles and increasing daily!
NavyPhrog is offline   Reply With Quote
Old 04-08-2012, 09:52 AM   #2 (permalink)
Jim Lembo's Avatar
Re: Largest rear tires on C5 Z
I've been running 315-30-18's on my car for a couple of years Jim. They fit the stock rim size and don't stick out past the fender lip. Can't say about the rear brake ducts as I removed mine years ogo when I was running 335 drag radials on 18x12" rims. (aftermarket) I need to put them back on, and I'm pretty sure the 315's will clear with the ducts on. I've never heard any different.
Jimbo
sig by GR8 White
Old 04-08-2012, 10:29 AM   #3 (permalink)
Thanks Jimbo. Im pretty sure after the ZSpeedFest I am going to need new rear tires and figued I would go big!
Old 04-08-2012, 02:13 PM   #4 (permalink)
ProfessorBlaze's Avatar
stock is 26.12 for 295/35-18
only issue with running a 315/30-18 is that the circ is off a bit.
circ-25.44
stock front is 25.34..
2001 TR C5Z with some stock mods and 74k Miles! Check it ouuuuut!
http://www.cardomain.com/ride/3820662
ProfessorBlaze is offline   Reply With Quote
Old 04-08-2012, 04:53 PM   #5 (permalink)
Thanks Blaze. That small difference shouldnt impact active handling or anything like that would it?
Old 04-08-2012, 05:32 PM   #6 (permalink)
Im interested to know as well, will 315 tire be larger so that they actually *make round* hence reduce the surface touching the road?(with road racing in mind here not drag) Thank you!
JL
Jlt230 is offline   Reply With Quote
Old 04-08-2012, 06:01 PM   #7 (permalink)
Jim Lembo's Avatar
I have 275-40-17's in front with the 315-30-18's in back and NO issues with AH/TC at all. I have read on other forums where some have had issues because of the diameters front to back being too close. I have always called BS on that simply because I haven't had any codes, ever!
Jimbo
sig by GR8 White
Old 04-08-2012, 07:56 PM   #8 (permalink)
MikesZ06's Avatar
Used to run 315 BFG's on my C5 back in the day and never had any issues or codes.
Old 04-09-2012, 06:06 PM   #9 (permalink)
JL
Not sure I understand what you're trying to say with "make round". The wheel size remains constant at 18" so if anything, there will be more rubber on the road so to speak.
Again, not sure I understand what you mean by "make round"
Cheers,
Jim
Old 04-09-2012, 06:08 PM   #10 (permalink)
Thanks again Jimbo, and thanks Mike.
Right now I am running 275/40/17s on the front as well and 305/35/18s on the back with zero issues.
Old 04-09-2012, 07:42 PM   #11 (permalink)
XFordGuy's Avatar
I run 315/30 on stock rear wheels for HPDEs. My only complaint is that you can feel the car shift on the tire in fast transitions. The rim really needs to be a half inch wider. Once I got past the spooky factor, it was OK. They don't rub anywhere.
Old 04-10-2012, 02:20 PM   #12 (permalink)
Hmm i tried to draw what i mean, its exaggerated but i think it shows what i mean by the tire making a round if its too large for the rim, i may be all wrong and tell me if i am please Thanks!
JL
Old 04-10-2012, 03:10 PM   #13 (permalink)
XFordGuy's Avatar
The picture helps. Yes, the tires stick out beyond the face of the rim. Here's a picture of a 315/30 on a 10.5" stock wheel. The tire extends nearly 1/2" (12mm) from the rim face on each side.
The "excess tire" is the reason a 10.5" rim isn't optimal for the tire. The tire moving side to side is the cause of the unpleasant sensation in transitions I was describing above. I got used to it.
Old 04-10-2012, 03:47 PM   #14 (permalink)
Z06 Tech Advisor
racingvette's Avatar
Really need a wider then 10.5" rim for those tires
I use 335/30/18s on rears but on a 12" wide rim.
Mike M - 2001 / 2008 Z06s
Old 07-25-2012, 03:44 PM   #15 (permalink)
We're running in a street tire class with our '03 Z06 ... using the rear wheel size in front, 18 X 9.5 with a 315/30/18 Kumho XS tire and a custom 17X12 CCW in the rear with 335/35/17 XS's.
The 18's give us great steering, the 17" rears help get the power down.
The rear wheels have about 3/8th inch off-set added so that we don't rub the fender liner on the inside.
Co-Driving '03 Z-06 in SCCA SS
Makofoto is offline   Reply With Quote
Can I use my rear tires for the front, and get 19's in the rear? Zee C5 Z06 - Grandstand 3 08-04-2011 08:33 PM
World's largest skateboard! jub jub The Garage (non Vette related) 7 07-16-2010 01:38 AM
Largest tire size? flyin6 C5 Z06 - Pit Road 10 11-28-2006 08:54 AM
Exxon = Largest Profit EVER! Roadracer247 The Garage (non Vette related) 11 10-27-2005 10:25 PM
One Of The Largest Z06 Allocations In The Country Rick1 Member Sales & Want-To-Buy - Parts & Cars 0 12-05-2001 07:34 AM
» Insurance
» Latest Auto News
Tesla CEO Elon Musk Fires Back at Chrysler
As expected, Tesla CEO Elon Musk has fired back after Chrysler issued
Infiniti Considering Mercedes CLA-Based Crossover
Infiniti is considering an entry-level crossover that would slot below
VL Automotive Looking to Buy Fisker for $20 Million
Fisker’s fall from grace is well documented, and it appears that
» New Car Reviews
2013 BMW X3 xDrive28i Review
2014 Scion tC Review - Video
2014 Lexus IS 250 Review
From staid to sultry
2013 Buick Enclave Review
» Featured Product
