Lifter Noise Fix- what else to do? - Z06Vette.com - Corvette Z06 Forum
Old 02-15-2013, 11:06 AM   #1 (permalink)
My bone stock 02 Z06 has had a noisy lifter at start up forever (75K miles). It starts quietly, but after about a minute a lifter starts a tapping noise. Once it gets a little warm and I rev it a little it quiets down. It seems to me that at some point the lifter may cause more serious problems for me. Do they fail at some point?
If I replaced the lifters at this point, what else should be done while the heads are off?
I am not interested in more power, just reliability and good mileage.
Also, who would you take it to in northern VA?
Thanks,
"ROSSO Z"
02 TR/Blk Z06, '04 shocks, CAGS Defeat, JETTCO Cup Holder, CCW SP-20's
Old 02-15-2013, 06:08 PM   #2 (permalink)
Re: Lifter Noise Fix- what else to do?
I have had the same issue for 73000 miles on my 2007 GMC. I have owned it since new and have done mostly synthetic oil changes no more than 5k. Sounds like one lifter bleeds down and taps for less than a minute. Drives me crazy. It bleeding down and the roller are two different things. So I have left it alone. If you feel you want to do it and are pulling the heads I would have to say also address tuning up your heads. Your at the mileage alot of valve springs have broken. I would check your wear and at a minimum put '04 springs in and new rollers then. Good luck.
Old 02-17-2013, 10:37 AM   #3 (permalink)
Mine is quiet at start up, but the tapping starts after about a minute and continues until I rev it a few times. I was wondering if a new cam would be a good idea, if I decide to replace the lifters, springs and rollers?
Thanks for your reply.
"ROSSO Z"
Old 02-17-2013, 12:08 PM   #4 (permalink)
I personally wouldn't change the cam unless you had some scoring on it from a bad roller. I would bet your issue is a rocker or lifter. If it has lasted this long I will bet it will last alot longer. Could be as simple as an oil passage in the lifter bore being a little gummed up. A cheap trick may work as simple as an engine flush prior to your next oil change. I have used Liquid moly w/ good results.
Valve Lifter Ls7 exportz06 C6 Z06 - Pit Road 0 02-17-2011 07:02 PM
'02 Z06 lifter broke what to do next PaulS C5 Z06 - Pit Road 0 01-23-2008 08:15 PM
lifter noise 405 hp C5 Z06 - Pit Road 11 07-08-2007 10:46 AM
Lifter Clatter Charlie78 C5 Z06 - Pit Road 4 10-11-2004 07:29 PM
Z went in yesturday for Fuel gauges, intake whine, and rocker/lifter noise. Gundam Z06 C5 Z06 - Grandstand 1 04-18-2001 10:31 AM
» Insurance
» Latest Auto News
Mazda to Debut New Model on Xbox Live
Mazda has teamed up with Xbox to produce the first-ever global live
2014 Aston Martin Vanquish Volante is Dripping With Sex Appeal
Aston Martin has just unveiled its 2014 Vanquish Volante, the first
Five-Point Inspection: 2013 Fiat 500e
As fuel prices continue to test the limits of infinity, small cars are
» New Car Reviews
2013 Honda CR-Z Review
Not hot enough and not eco-enough
2014 Mercedes-Benz E350 Wagon Review
Wagons East: This Benz is Sweeter than Candy
2013 Audi RS5 Review - Video
The last of a breed and the best of the bunch
2014 Chevrolet Impala 2.5L 4-Cyl Review
Are four cylinders two too few for Chevy's new sedan?
2014 Kia Rondo Review
You can't buy it, but do you even want to?
» Featured Product
