Old 06-29-2004, 07:41 PM   #1 (permalink)
lowering Z06
New guy here,
Quick question about why do corvette drivers lower there cars? Is it for : 1) cosmetic purposes, 2)for better handling or 3)for less air drag. And if I decide to do it how much would it cost? and will GM dealer do it for me and will they still honor their garantee?
Hope to hear from you Z06 dudes soon
Levendi is offline   Reply With Quote
Old 06-29-2004, 07:49 PM   #2 (permalink)
Tom Fuscaldo's Avatar
I lowered mine for better handling and better looks. The cost was nothing. We lowered about 7 Z06s at a recent Z06vette.com gathering. The dealer shouldn't charge you much more than a hours labor and it shouldn't even take them that long. There is no effect on the Warranty. Wait about two weeks after you lower it and have the dealer do a alignment. You will need one...
Tom Fuscaldo is offline   Reply With Quote
Old 06-29-2004, 07:58 PM   #3 (permalink)
Looks
Old 06-29-2004, 09:29 PM   #4 (permalink)
I have been wanting to do this but the only two things holding me back.
1. I run DRs at the track. Will this hurt me in anyway?
2. How much does a alignment cost.
After seeing Z06s that are lowered I really want to do this to my car. It looks so cool.
RPM CNC Stage 3+ Heads, Comp Cams, Push rods, ASP Pully, Kooks Headers, Kooks X-pipe, 4.10 Gears, Borla Stingers, RAM Stage 4 Clutch, Aluminum flywheel, Adjustable Master Cylinder, Hardened Output Shaft, Rearend Strut, Hurst Shifer, Vararam intake, BFG Drag Radials, Z06 Partition, 489RWHP
need4sp471 is offline   Reply With Quote
Old 06-30-2004, 04:52 AM   #5 (permalink)
I don't know if lowering will hurt you at the track. I lowered mine to get rid of the gap between the tire and the fender well. I had mine done at Southwest Alignment in Houston for $90.00. He knew his way around Corvette's and did an excellent job.
wlxx861 is offline   Reply With Quote
Old 06-30-2004, 05:18 AM   #6 (permalink)
Dragon's Avatar
Lowered mine for looks. The High Performance Suspension Class at CVCC in Hickory, NC lowered mine as a class project. It only cost $19 for 2 Grade 8 bolts, nuts and washers. After driving it they also aligned it with a little less negative camber for the street at no cost. The ride is a little firmer but not harsh and the handling is better even though I was going for looks.
"It's never too late to realize what's important in your life."
Dragon is offline   Reply With Quote
Old 06-30-2004, 06:11 AM   #7 (permalink)
I lowered mine for looks and for handling. I love the car slammed. It is awesome. Do it and don't look back. haha
Come to the Z06 Fest!
Performin' Norman
Old 07-01-2004, 07:22 AM   #8 (permalink)
Just met another ZO6 owner at a car show last Sunday and he got a quote from Carvaggio to lower his Z $450.00 Canadian about $300.00 us.
A friend of mine did 2 cars in 2 hours and cost nothing.
See if you can find someone in the Montreal area that can do this for you.
Don
2002 Electron Blue
500.26 rwhp
489.09 tq
LONGGONE is offline   Reply With Quote
Old 07-01-2004, 07:28 AM   #9 (permalink)
Send a message via AIM to benenati379 Send a message via MSN to benenati379 Send a message via Yahoo to benenati379
Can someone post a pic of before and after lowering on the stock bolts. Been thinking about doing this. Does it make noticeable difference in looks?
Vince
benenati379 is offline   Reply With Quote
Old 07-01-2004, 07:31 AM   #10 (permalink)
This is a very simple procedure. It takes longer to get the car up on jack stands and take the front wheels/tires off than it takes to lower the front end. The rear is easier. No need to remove anything. I did half my car yesterday. It got dark and I did not have the correct size wrench for the nuts on the rear (13/16ths). Will complete the rear this afternoon.
Hopefully those prices that LONGGONE quoted included an alignment because that seems way high just for lowering.
NCM Familiy Member #23009
lasmith2112 is offline   Reply With Quote
Old 07-01-2004, 10:29 AM   #11 (permalink)
Dragon's Avatar
Stock height with original wheels.
Lowered with powder coated wheels.
Old 07-01-2004, 12:38 PM   #12 (permalink)
Thanks Dragon, I didn't know it made that much of a visual difference.
Old 07-01-2004, 10:55 PM   #13 (permalink)
THATS ALOT 450can to lower the car I spoke to a frined of mine who
owns a grage he said hill do for 100 can I LOVE THE WAY IT LOOKS
so F---MEAN I WOULD DO IT IN ABOUT TWO WEEKS.
THANKS BOYS FOR INFO
GO GREECE GO
Old 07-02-2004, 04:43 AM   #14 (permalink)
For those that lowered on the stock bolts, using the how to from this site, does the car retain the rake? I have about a 1/2 rake from front to back.
Old 07-02-2004, 05:37 AM   #15 (permalink)
Bolts
Dragon> what size grade 8 bolts are needed & are they for the front or rear?
Thanks
ZBESTC5 is offline   Reply With Quote
about lowering z06 yourself COUTO1981 C5 Z06 - Pit Road 1 12-07-2004 09:54 AM
lowering a Z06 pauliegerm C5 Z06 - Pit Road 12 03-26-2004 03:25 PM
Lowering a Z06 911response C5 Z06 - Pit Road 12 10-12-2003 04:39 AM
lowering Z06 vipereater C5 Z06 - Grandstand 12 07-14-2002 03:14 PM
lowering z06 qik z06 C5 Z06 - Pit Road 3 01-27-2002 10:46 AM
