Old 07-04-2009, 10:32 PM   #1 (permalink)
Main Drive Belt Jumping Groove
Hello, all, and thanks in advance for any advice offered. I have not had this 02 Z very long, and have noticed that the main drive belt is "jumping" out of line by a groove. Anyone else had this happen? Is this an alignment issue? I've found it this way twice. It is simple enough to get back in line, but I want to get to the root cause. Thanks again.
johnryanbuilder is offline   Reply With Quote
Old 07-05-2009, 10:09 AM   #2 (permalink)
Re: Main Drive Belt Jumping Groove
I've lost a few belts at the track. Common cause seems to just be the belt and not any misalignment of any of the driven components. Everytime I've had the same problem, I put a new belt on and its good for quiet a while. I recommend a new belt for you. But, when the belt is off, I'd check the driven components, such as the alternator, for excessive longitudinal play (e.g. in line with the shaft which would cause it to be out of line with the belt).
2004 SCCA MidWest Division T1 Champion
AMSOIL Direct Dealer
Old 07-05-2009, 11:33 AM   #3 (permalink)
RocketSled's Avatar
I agree with SubD. There's not a lot that can get misaligned in a stock LS6 accessory belt system. But the belt can jump due to a soft tensioner, and/or a stretched belt, particularly when you're hitting the shifts *hard*. You're new to the car, so you might not have any maintenance history, but it costs little to just replace the belt. That being said, I know that a Kevlar OEM-sized replacement is available - I'd get that if I could find it someplace. The kevlar backed belts are substantially stronger and more resistant to stretching than the standard belt.
My setup is far from standard, and I had a problem with the belt jumping, not due to alignment, just due to the loads being placed on the belt combined with my style of driving. When I finally switched to a kevlar belt, my problems disappeared. I keep a spare belt in the car just in case, but I haven't thrown a belt in 2 years.
C6!
Old 07-05-2009, 02:48 PM   #4 (permalink)
Pit Man's Avatar
Where are you finding the Kevlar belts ?
Pitt
2000 Silverado, Best 1.54 sixty, 402 Stroker NA, 410 gears, Pete Incaudo Street cam & reworked top end 11.17 ET & 119 mph
Pit Man is offline   Reply With Quote
Old 07-05-2009, 09:12 PM   #5 (permalink)
RocketSled's Avatar
I think I ordered mine from Vortech, since the problem was in large part due to the Blower and an effect called "reflected inertia" (when the engine speed changes suddenly, all the spinning accessories have inertia that must be overcome by the belt. The blower adds a *lot* of inertia to the system. The effect on the belt is as if those accessories continue to "push" the belt faster than the motor wants the belt to be moving and that causes the belt to stretch and go slack on the tensioner side of the loop). But if I recall, it's a "Gates" manufactured belt, it ought to be available other places besides Vortech (the Vortech belt routing is radically different from OEM, but Vortech had the courtesy to keep the same overall belt length as stock).
Old 07-08-2009, 03:59 PM   #6 (permalink)
Last C5's Avatar
While you're at it replace your stock tensioner with an LS2 tensioner. They have taller sidewalls and accomodate the Zs sometimes erratic belt movement. My buddy's 02Z was doing what yours is doing and that solved the problem completely. It's a direct bolt on replacement.
Last C5 is offline   Reply With Quote
Old 07-15-2009, 11:21 AM   #7 (permalink)
Thanks for the info guys. So far so good with a new belt. The tensioner seemed fine so I went ahead and left it on more out of curiosity to see if it was the belt or tensioner causing the problem. Once I'm satisfied, I'll go ahead and replace the tensioner just as a precaution, and I'll try the LS2 unit.
Main Drive & AC Belt Replacement LeRox C5 Z06 - Pit Road 5 12-16-2008 05:13 PM
Magna Charger Drive Belt NYCHASM C5 Z06 - Forced Induction & Nitrous 3 08-13-2006 09:57 PM
**DTE HD Vortech S/C Belt Drive Kit** (photos) Dynotech Eng. Vendor Sales - C5 14 01-04-2006 11:25 AM
Like Jumping Out Of Planes?Think Twice Look artnj04z06 The Garage (non Vette related) 1 12-05-2005 05:08 AM
Jumping off the Zaino Bandwagon... IMBLISS Vendor Sales - C5 44 09-03-2002 03:56 PM
» Latest Auto News
Furious Fuchsia Dodge Challenger Celebrates 40 Years of a Muscle-Car Icon
Dodge is once again releasing a new special edition versions of its
Chicago Preview: Nissan 370Z 40th Anniversary Edition Set for World Premiere in Chicago
Just last week we thought we’d have to wait for the New York
Chicago Preview: 2011 Infiniti M37, M56 Set for Public Debut
While the media was given a sneak peak at the all-new 2011 InfinitiĀ
» New Car Reviews
2010 Lamborghini LP560-4 Spyder Review
With Lambo's new LP560 Spyder, taming the bull has never been so easy,
2010 Nissan Pathfinder SE 4x4 Review
Nissan's rugged Pathfinder is an old-school standout
2010 Chicago Auto Show Preview
The Chicago Auto Show might not have the media hype of such events as
2010 Toyota Camry SE V6 Review
An SE trim level adds a little sport to the Camry, making living with
2010 Subaru Legacy 2.5i Premium PZEV
Subaru's 2010 Legacy gives up some of the brand's more endearing
