Old 01-23-2006, 01:59 PM   #1 (permalink)
Send a message via ICQ to N2O4YOU Send a message via Yahoo to N2O4YOU
Need help on Gear Ratio
I am planning to replace my rear with a DTE Unit with hardened component and am thinking of changing gearing while I was at it. My car is 03 ZO6 with 477RWHP on 100 hp shot of Nitrous(rest of mods in sig). I plan to add headers and maybe a cam later but that will be the extent of my mods for this car. I DO NOT use the nitrous on the street so i'm looking for more fun on the street. I was thinking 3.90 or 4.10 gears. Will 4.10 be too much with my HP at the track with DR's. I will probably move to ET's next year.
Thanks in advance.
TSP Torquer 2 cam, NX Wet and Genx2 kit, Nitto 555R Dr's, Halltech SSM, BB Bullet, Custom X-pipe, DTE Stage 3 Rear(3.90)& Brace, RPM Trans,LG Street Headers.
N2O4YOU is offline   Reply With Quote
Old 01-24-2006, 09:42 AM   #2 (permalink)
Z06phile's Avatar
Location: South AL/// Z06 Fest Participant I II III IV V VI VII
What DTE rear are you getting, stage 1 or 2? I'm planning on getting a stage 2 with a strut brace.
I'm leaning towards a 3:73 myself since I've had several people tell me that anything shorter would'nt be a good idea for a Z with nearly 500 rwhp. The 3:73 gear will be a little more durable than the 3:90 too. The 3:90 would probably be a good choice for you on the street, but your N2O 1/4 times might suffer.
Traction is almost non existent in 1st & 2nd gear on these F1SC tires with the 3:42s, so the only reason I'm even considering a shorter gear is the advent of the Nitto RII.
'01 Z06 Lingenfelter 383 Stroker w/ all the bolt-ons, braced DTE 3.90, Pfadt coil overs, Stoptech BBK, 18/19 iForged Aero
'04 CTS-V Hotchkis ARBs
'08 Honda S2000 CR daily driver
Z06phile is offline   Reply With Quote
Old 01-24-2006, 10:06 AM   #3 (permalink)
3.90's are the best bank for the buck in your HP range. (MN12 Z06 tranny). For the MN6 tranny 4.10's are best. As you go up in HP your go down in ratio's. By the time you get to a 427 stroker motor you are back to stock gearing or even less.
Old 01-24-2006, 10:43 AM   #4 (permalink)
I contacted DTE and they are updating their stages.
The one I am getting is now a Stage 3.
Hardened shafts both sides, Flow-through oiling, HD clutch pack, Engineered to accept LG oiling system, plus all standard upgrades. I will also install their Dif.Brace
Jim
Old 01-24-2006, 09:46 PM   #5 (permalink)
i have run DTE rear end with 4:10's for almost a year. i love the setup car runs 70 m.p.h @ 2100 r.p.m. awesome acceleration 1.6 60 ft time with et streets and it makes 6th gear usable.
diegoz06 is offline   Reply With Quote
Old 01-28-2006, 04:30 PM   #6 (permalink)
I've mannaged a few 1.6 60' myslef on Nitto DR's. I think the 4.10 would be a blast on the streets but I'm unsure if I will be able to get traction with the Nitrous at the strip.]
What's your power level?
Jim
Old 02-01-2006, 11:42 PM   #7 (permalink)
My Car Makes 430 R.w.h.p. I Run Et Streets When I Drag. Consistant 1.6 60 Fts
Old 02-02-2006, 08:33 AM   #8 (permalink)
Do you think that your set-up would still hold traction with an additional 50-60HP?
Old 02-04-2006, 06:12 AM   #9 (permalink)
yes i think so may have to play with the launch possibly lower r.p.m.'s. on street tires the car will break loose in 1st 2nd and 3rd.
Old 02-04-2006, 07:15 AM   #10 (permalink)
Thnaks for the info.
Old 02-04-2006, 02:01 PM   #11 (permalink)
Send a message via MSN to tlaselva
Originally Posted by D.I.R.E. C-5
I I was thinking 3.90 or 4.10 gears. Will 4.10 be too much with my HP at the track with DR's. I will probably move to ET's next year.
With shorter gears, your increasing your torque numbers, not HP.
Shorter gear = More torque, less HP.
Taller gear = More HP, less torque.
Your gearing will determine the characteristics of your power in respects to HP & Torque.
There is no free power. In respects to gearing, if you gain in hp, you loose torque, and vise versa.
2006 C6 Z06
Sorry bro, can't advertise for non site vendor in your sig
Lingenfelter 427 CID 616 BHP : Caravaggio Full Leather & Alcantra Interior : PHADT Coilover & Sways
tlaselva is offline   Reply With Quote
Old 02-04-2006, 02:31 PM   #12 (permalink)
JTS
Have you had any drive train problems running that 60'?
01 Torch Red ZO6,
LG Lt headers, B&B cat back,vararam, f-14 high lift, asp pulley, 434hp/417ftlbs, and more to come......
JTS is offline   Reply With Quote
Old 02-04-2006, 03:27 PM   #13 (permalink)
Z06 Power Adder Authority
In my mind, the most important aspect to consider when lowering the gear ratio (raising it numerically) is whether or not you'll "run out of gear" in a full 1/4 mile race.
Your trap speed of ~116mph on nitrous (?) seems extremely low. I'm going to guess you either 1) let off at 1000' on that run or 2) that is a N/A run, not a nitrous run.
Anyway, looking at your RWHP/RWTQ I would guess a trap speed of ~128mph or so. So, my advice would be to run whatever gear you can without going over redline in 4th gear at ~128mph...and then address your traction issues as needed.
My guess is that will be 3.90s.
'06 300C SRT8
'06 Trailblazer SS
Old 02-04-2006, 06:46 PM   #14 (permalink)
Thanks for advice. I'm thinking I will go with 3.90's.
Old 02-04-2006, 07:14 PM   #15 (permalink)
no DTE makes a great rear end. i did have a MC LEOD street twin clutch and i had some drive train problems but i switched to a ls7 clutch with a ls2 fly wheel and the car feel great. i do have the DTE tranny brace.
Tuning for gear ratio change JMFND C5 Z06 - Tuning & Electronics 2 06-29-2007 03:07 PM
Motive Gear 3.73 Gear Ratio Shortage Dynotech Eng. C5 Z06 - Pit Road 4 02-18-2005 08:48 AM
gear ratio, how much will it help in the 1/4! 405bhp C5 Z06 - Pit Road 4 11-23-2004 04:09 PM
Transmission - 5 Gear Ratio Change?? VAI C5 Z06 - Pit Road 10 07-20-2004 07:07 AM
4.10 gear ratio? 405bhp C5 Z06 - Pit Road 11 04-18-2004 11:56 AM
