Old 11-24-2001, 10:19 PM   #1 (permalink)
need instruction on changing radiator fluid...
car is one year and want to change radiator fluid.
any tips/hints on doing this?
any link to tech page on how to do it?
should you always do a flush before replacing?
is it possible to do without lifting car?
thanks,
don
don527 is offline   Reply With Quote
Old 11-24-2001, 10:58 PM   #2 (permalink)
As I recall, Dex-Cool does not have to be changed like conventional fluid. I think its like 3-5 years
JC
Need tires? Get em from Tirerack by clicking the ad and the forum gets 5%!
N4C5S is offline   Reply With Quote
Old 11-25-2001, 04:40 AM   #3 (permalink)
Vette Doctor
c4c5specialist's Avatar
HI Don,
I do agree with JC here, as the DEx-cool is good for up to 5yrs/100k. The non silicate formula is very good as lubricating the waterpump bearings, and prohibiting deposits inside the cooling system.
Obviously, its all relative on how the driver uses his car, however, I recommend that after 3 years, have the Dexcool checked for deposits, freezin, and boiling temperature.
Also, critical in changing any antifreeze is the need for distilled water.
Besttoyou, c4c5
Old 11-25-2001, 01:27 PM   #4 (permalink)
Great info, thanks C4C5.
I was thinking about changing mine also, but now I will wait awhile.
Have any of you used that Redline Watter Wetter? If so any results?
Thanks
Rollin Black is offline   Reply With Quote
Old 11-25-2001, 02:27 PM   #5 (permalink)
Thanks C4C5,
I just past the one year mark and was thinking of things to do. Besides oil/filter, I've already changed the rear gear and tranny oil this year at the dealer and figured radiator and brake may not be bad if it wasnt too tough for myself but, with the info you gave, I can put it off for a little longer.
Rollin,
I've used Watter Wetter in my Ninja days and the stuff works. Water temp did decrease... about 10%. It's suppose to provide lubrication and knew people on the track that swore by it because they were not allowed to use coolant on racing bikes and the Watter Wetter helped with straight water. This was back in 94.
But I havent researched it to know if there are any quirks in using it with the Vette and the type of fluids they use for it. Lemme know what you find out.
Don
Thanks
Old 11-27-2001, 05:56 PM   #6 (permalink)
Hi C4C5,
Why distilled water? I know distilled water has no minerals but still will have oxygen. Oxygen causes rust.
Thanks, Bob
Bob57 is offline   Reply With Quote
Old 11-27-2001, 06:51 PM   #7 (permalink)
Its about the minerals. Use of regular water can cause calcification and deposits to occur........
Did you know that you can check the condition of the coolant with a voltmeter? Ok, so its not the most accurate method, but it works, kinda like fire from ice eh
JC
Old 12-04-2001, 10:43 AM   #8 (permalink)
The owners manual says to replace the coolant at I believe 5 years or 150,000 miles. Of course just like oil changes this is a one size fits all recomendation. Different operating conditions may require different change intervals to achieve the best protection for the engine.
Dex Cool made by Havoline for GM, adds organic acids to ethylene glycol as additives instead of using silicates & phosphates that are added to conventional green or blue antifreeze. The organic acids last much longer and almost eliminate hard water deposits from forming & there is much less abrasion to the waterpump seals.
DO NOT: Use tap water. Use Distilled water only. It has been reported that Dex Cool reacts with chlorinated tap water, creating corrosion problems & sludge plugging up the cooling system.
DO NOT: Mix Dex Cool & regular anti freeze. If in an emergency the two are mixed get the system flushed as soon as possible and refill with the correct coolant.
DO NOT: Start using Dex Cool in a vehicle that did not come with Dex Cool from the factory. The silicate deposits are already in place & will keep the organic acids from working.
With the longer change interval DO NOT forget about changing your coolant. There is a large gremlin lurking out there. It is electrolytic metal corrosion (EME). EME is the damage done to engine parts by coolant (orange or green) reacting with the high amount of aluminum in newer vehicles. The cooling system becomes a storage battery resulting in pitting and cratering of blocks heads timing covers radiators etc. This may be mistaken for bad castings or other causes but it is EME.
There is a simple test for EME. Take a multi meter & put it on the lowest DC voltage range. Stick the positive probe in the coolant at the radiator cap. On your corvette stick the positive probe in the coolant in the reservoir. Hint you may need to use a piece of bare wire or other metal extenton to reach the coolant. Then touch the negative probe to the engine. If EME is present the meter will read between 0.5 and 1.75 volts. If the reading is in this range change the coolant. This is not stray current from the electrical system. It will work even with no battery in the car.
This test is so easy to do I will be doing it occasionaly & if it starts getting near 0.5 volts I will be off to the store for some Dex Cool & distilled water! Even if you keep passing this test do not ignore the time or mileage change criteria. The organic acids deplete over time and need to be replaced. To be safe I won't be waiting 5 years to change mine. I checked my 2002 Z06 last nite. The car has 500 miles on it. I got a reading of 0.10 volts.
If anyone else wants to use additives (water wetter etc. help yourself. But remember you are altering the chemical makeup of the coolant and the results are unknown to the user. Make mine a Dex Cool & Distilled Water only thanks.
If any one has waided through all of this I would like some tips. How can you drain/flush the cooling system at home. I have not been able to locate the block drains on my 2002 Z06. I do not want some one else working on my car so I want to be able to do it myself. HELP PLEASE
Terry S is offline   Reply With Quote
Old 12-04-2001, 11:09 AM   #9 (permalink)
To drain the coolant, remove the resevoir cap (to release the pressure) and then open the drain plug. The drain plug is located on the bottom of radiator, right side (white plug). Takes an Allen wrench to open it, can't remember the size. It does not come off, simply turns to open. Done it twice so far to change the TSAT, easy as can be.
MARZ06 is offline   Reply With Quote
Old 12-04-2001, 11:51 AM   #10 (permalink)
Thanks Z06 Addict. I knew where the radiator drain is but to do a good job of draining & flushing the system when changing the coolant you need to drain both sides of the block. Otherwise you leave most of the coolant in the block if you just drain the radiator.
It looks to me like the block drain plugs (if they are there) are going to be a real bear to get to.
Is there a doctor in the house?
Old 02-02-2003, 07:02 AM   #11 (permalink)
How to change/flush the coolant from the GM manual
I don't see where its tell you how to drain the block.
Draining and Filling Cooling System
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
Park the vehicle on a level surface.
Remove the surge tank cap:
Slowly turn the cap counterclockwise 1/4 to 1/2 turn and stop. Do not press down.
Allow any residual pressure, indicated by a hissing sound, to be relieved.
After all residual pressure stops, continue turning the cap counterclockwise.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Place a drain pan under the drain cock.
Open the radiator drain cock.
Allow the cooling system to drain completely.
Inspect the engine coolant for the following:
Discolored -- follow the flush procedure below.
Normal in appearance -- continue with the next step.
Notice
When adding coolant, use DEX-COOL® coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner-at 50 000 km (30,000 mi) or 24 months.
Notice
DO NOT use cooling system seal tabs (or similar compounds) unless otherwise instructed. The use of cooling system seal tabs (or similar compounds) may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Close the radiator drain cock. Tighten
Tighten the radiator drain cock to 2 N·m (18 lb in).
Fill the cooling system through the surge tank.
Fill half the capacity of the cooling system with 100 percent DEX-COOL® coolant.
Slowly add clean drinkable water to the cooling system until the level reaches to the base of the neck.
Start the engine.
Allow the engine to idle for 1 minute.
Install surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
Shut off the engine.
Refer to step 2 above in order to remove the surge tank cap.
Start the engine.
Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
Install the surge tank cap.
Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
Rinse away any excess coolant from the engine and the engine compartment.
Inspect the concentration of the engine coolant.
xxxxxxxxxxxxxxxxxxx
Flushing
Important
Do not use a chemical flush.
Store used coolant in the proper manner, such as in a used engine coolant holding tank. Do not pour used coolant down a drain. Ethylene glycol antifreeze is a very toxic chemical. Do not dispose of coolant into the sewer system or ground water. This is illegal and ecologically unsound.
Various methods and equipment can be used to flush the cooling system. If special equipment is used (such as a back flusher) follow the manufacturer's instruction. However, always remove the thermostat before back flushing the system.
Block the drive wheels.
Place the transmission in park (P) or neutral (N).
Engage the park brake.
Run the engine until the thermostat opens.
Stop the engine.
Follow the drain and fill procedure using only clean drinkable water. Repeat the procedure if necessary, until the fluid is nearly colorless. Refer to Draining and Filling Cooling System .
Fill the coolant reservoir to the FULL HOT mark.
Fill the cooling system. Refer to Draining and Filling Cooling System .
Old 02-02-2003, 08:10 AM   #12 (permalink)
I just did the test on my 01 with 28,500 miles. I got a reading of 0.20 volts.
Old 02-02-2003, 10:28 AM   #13 (permalink)
DJWorm's Avatar
If you really want to help your cooling system:
1. Drain out enough to change the TStat and replace the TStat with 178 degree unit
2. Drop in 2 bottles of Red Line Water Wetter
3. Fill the balace with distilled water to reduce the Water/ DexCool ratio from 50/50 to as low as 70/30. If you are in the South (non freezing temps) or hot summer racing in the Northern Climes. Add Dex Cool when the temp cools down to 40 degrees OAT.
4. Consider a fan controller or reprogram the fans to come on at a lower temp.
5. When in stop and go traffic or sitting in the grid on a hot day run the A/C with the selector (right button) in the "ReCirc" ON mode. This will turn the fans on sooner and higher (both the A/C fan and the radiator fan).
If you are still not reaching the temps (cooler) you need replace the radiator with a 4 core from mallett or a Ron Davis with integral oil cooler fron Doug Rippie.
www.mallettcars.com
www.dougrippie.com
Old 08-24-2004, 07:49 PM   #14 (permalink)
Three years after posting this thread...
I'm ready to change the radiator fluid.
I ended up not doing back then cause C4C5 and others gave me the impression that it could wait. Now the cars coming close to 4 years old and thought, "Now is it time to change it?"
The fluid color still looks great and a tester showed A-OK ... I would think it should since the car has only got maybe 10k on the odometer.
Question on the instructions below....
1. Should the engine be warmed up at operating temp before draining the radiator fluid or ok to drain cold?
2. If I were to follow the flush procedure it says, "Run the engine until the thermostat opens."
How do I know when the thermostat opens?
Thanks,
Don
fluid.
thanks,
don
Old 08-25-2004, 09:10 AM   #15 (permalink)
You'll know when the thermostat opens when the upper radiator hose gets warm. Likewise, in the Shop Manual it says to initially drain the coolant with the surge tank cap ON--this will allow the pressure in the system to also drain the surge tank.
Melsy
'03 Red/Mod Red
Melsy is offline   Reply With Quote
Changing Diff fluid Yakisoba C5 Z06 - Pit Road 6 02-12-2006 07:42 PM
Changing cluth fluid, which is best to use? george C5 Z06 - Pit Road 3 08-09-2004 09:17 AM
Changing brake fluid -- what should I use? 1g1yy C5 Z06 - Pit Road 11 05-11-2004 04:21 AM
Changing Tranny Fluid NavyPhrog C5 Z06 - Pit Road 11 11-26-2002 05:00 PM
Changing brake fluid FRF Z06 C5 Z06 - Pit Road 21 03-28-2002 02:07 PM
