Old 06-16-2005, 07:49 PM   #1 (permalink)
need port an polish advice
So botom line is the left side head has to come off. My mehcanic thought that since I gotta pay the dough to take the head off why not have them prted and polished. He says he can get me 100 more horsepower while still retaining liability.
Does this sound right
also since he is doing the heads should I also have him do the cam, IE how much more labor is invovled in getting the cam out.
Finally any suggestions on milling numbers or any other specs I should consult with my mechanic about
any advice would be greatly appreciated
thanks
oh yeah one more Q
so i need to worry about my clutch since, or do you think the stock Z06 clutch will be able to handle the extra ponies
Polar Bear is offline   Reply With Quote
Old 06-17-2005, 08:01 AM   #2 (permalink)
100 HP with just head porting would be great and I would love to know how he does it. I would ask to see his work if you haven't already and also request the flow data from his flow bench @28 inch of H2O. Compare his data to published flow data say from AFR and other sources. Also before and after RWHP and Torque data from other customer cars. Notice at what RPM the power occurs and what the HP/Torque graph looks like. Wide power band vs a peaky high RPM band. Also see how fast his peak number fall off after their highest point. Ask if he is going to install larger valves and if so how large and does he plan on installing larger valve seats. The cam combination is very important at this point to work in conjunction with new flow numbers so get the spec's on the cam/valve springs/retainers and compare his data to what the vendors on this site offer and what guys on this site are using successfully. Ask him why he is picking this cam for your engine out of all of the cams to choose from. Head milling will be required if he cleans up your combustion chambers to balance things out and retain your stock CR. You could have more material removed if desired to increase CR.
This guy could be the next Bill Jenkins or Joe Blow from Idaho so check him out before he lays a die grinder on your heads.
I'm sure you have thought of most of this stuff already but just wanted to chime in with my two cents.
D.J.
2007 Silver Z06
2000 Coupe
Old 06-17-2005, 08:24 AM   #3 (permalink)
30 to 40 HP gain. So with Headers, stock cam, tuning and ported LS6 heads, you should be at 420 RWHP.
Old 06-19-2005, 03:39 AM   #4 (permalink)
Send a message via Yahoo to softy91
I think the point is that your engine is being opened up and now would be a great time to do some mods.
I would consider what your machanic is offering, but--I would also talk to some of our vendors. You could use his labor and your choice of parts. Now would be a good time for a H/C package and don't forget the timing chain and oil pump. You would be good to go!
CR 10.9 to 11.0 is about the max on pump gas and a daily driver.
As they say in LV, Good Luck!
07 Z06 LMB HP Tunners and PS2's
Sold! 02 EB Z06 -TRAP, LMG, Dyno, Denso Iridum, HP Tuners, CA Vanity Plate "Z06Vette"
98 Regal GS Modified to 13lbs of boost and electronics package
2000 Road King Classic -CaliforniaSE 95" heads and cams
softy91 is offline   Reply With Quote
Old 06-20-2005, 03:52 PM   #5 (permalink)
yeah i am doin a cam as well
roller rockers valave springs
i had not thought about timing chain and oil pump.
what else ya think i should get
Old 06-21-2005, 10:45 AM   #6 (permalink)
Your other mods are good to go!
If you are really bucks up some more displacement might be nice, but how much is too much?
AFR 205's Patriot stage II, or MTI 2E port and polish with cam Polar Bear C5 Z06 - Pit Road 30 02-09-2006 05:01 AM
port/polish work fluff Vendor Sales - C5 2 09-04-2004 08:24 PM
Problems with OBDII port? minivette C5 Z06 - Pit Road 3 09-05-2003 11:49 AM
Menzerna Polish and Finish Polish tmelita C5 Z06 - Grandstand 6 05-19-2003 10:28 AM
Abrasive Media Port/Polish - Reference DJWorm HPDE 0 12-15-2001 06:55 PM
