View Poll Results: which oil do you use?
5w20 2 0.91%
5w30 150 68.49%
10w30 56 25.57%
10w40 11 5.02%
Voters: 219. You may not vote on this poll
Old 04-21-2005, 06:07 AM   #1 (permalink)
Oil specs!!!!!!!! which oil do u use?
I was just wondering what oil do you use?
and what makes the diffrence in oil specs diffrent, for instance 5w30 like most of us use, what weight is that oil?
will using a lighter oil weat the motor? wouldnt make the motor more power since less weight to move around?
Old 04-21-2005, 06:10 AM   #2 (permalink)
If you use what GM recommends, you won't go wrong
Old 04-21-2005, 06:14 AM   #3 (permalink)
Mobile One 5w30 every 3k or 6 Months!
2002 EB/ModRed... Vararam VR2B w/ K&N, WCC Power Coupler, MSD 8.5 SC W/NGK TR55's, Brembo D&S, Hurst SS w/Q-Ball Knob!
SGT. PYLE is offline   Reply With Quote
Old 04-21-2005, 06:16 AM   #4 (permalink)
This has been beat to death. 5x30 mobile one, southern states or hot summer 10x30.. :drunk:
01 Z06 ATI D1 Procharger 13lbs 383 Forged CnC Heads TPIS headers
RPS Clutch 660 RWHP--650 RWTQ
Veteran Viet Nam 5th Special Forces Abn
dbvettez061 is offline   Reply With Quote
Old 04-21-2005, 06:21 AM   #5 (permalink)
you didnt get my point!!
IF Its been beaten to death, where?
but really what I mean is not for my use! its out of curiosity, will lighter oil make the motor rev free and give more power?
Just out of curiosity, what is the lightest oil ?
Old 04-21-2005, 08:52 AM   #6 (permalink)
Actually using a lighter oil will produce more HP...but will it protect as well? In instances where you are trying to get every bit of HP you can; isn't that also where you are stressing the engine the most, such as in competition.
There have been studies and tests done to support your supposition. For instance a specially formulated race oil that has friction modifier chemistry, electrostatic adhesion properties and high shear resistance has been marketed at 0W20 and shown to produce higher HP and Tx. This oil while running at low viscosity will cut oil drag but will maintain a low wear film on stressed componants.
Here are the result comparisons:
15W50
Baseline Max HP @ 9750 RPM
Baseline Max Tx @ 7300 RPM
5W40
+ 3.7 HP @ 9750 RPM
+ 1.9 Ft# @ 7400 RPM
0W20
+6.5 HP @ 9750 RPM
+3.1 Ft# @ 7400 RPM
The Lower Vis, Special Racing Oil netted a 5% HP increase and a 4% Torque increase. It's interesting that the Max. Tx figure was achieved at +100 RPM with lighter oil. It was also noted in these tests subjectively that the driver thought acceleration was better and throttle response was a little crisper.
You must also be concerned with oil pressure and oil flow under these conditions. Using this Low Vis oil would require a ported and polished oil pump, possibly a larger oil pump, a higher pressure output spring and higher pressure shimming. I would also recommend changing the oil after each event.
On the other side of the coin many competitiors in stock classes experience lower than normal pressures during competition in hot weather. They opt for the higher Vis 15W50 which flows as well in hot conditions and offers (normalized) higher pressures.
Bottom Line. Use a quality Synthetic. Use a higher Vis if competition oil pressures drop too low during hot weather events. You may consider a Lower Vis Racing Oil (for HP & Tx gains) but you must also modify the oil pump for higher output and be sure the oil has friction modifiers an adequate shear resistance for racing.
Old 04-21-2005, 09:22 AM   #7 (permalink)
DJWorm, thats exactly what I was looking for, thanx
Old 04-21-2005, 11:05 AM   #8 (permalink)
Z06phile's Avatar
Location: South AL/// Z06 Fest Participant I, II, III, IV, V, VI, VII, VIII
Good info, DJWorm.
'01 Z06 Lingenfelter 383 Stroker w/ all the bolt-ons, braced DTE 3.90, Pfadt coil overs, Stoptech BBK, 18/19 iForged TE10
'08 Honda S2000 CR
'04 CTS-V Hotchkis ARBs
Z06phile is offline   Reply With Quote
Old 04-21-2005, 12:09 PM   #9 (permalink)
Not another oil thread !!!!!
Short answer it's a 30 weight the first number has nothing to do with weight just it's ability to flow at colder temperatures . It is not a 10 weight oil when it gets cold . I can't think of any fluid that gets thinner as it gets colder can you . I use Amsoil series 2000 0 W 30 I have experienced no drop in pressure at all . I suggest you do a Goggle search for " THE MOTOR OIL BIBLE " it's a good read . Maybe you could add 0W30 to the poll JMHO
If you always do the right thing you will amaze most and astonish the rest -Harry S. Truman
OLDGUY is offline   Reply With Quote
Old 04-21-2005, 03:23 PM   #10 (permalink)
My actual experience.
I have vettes oil changed every 1,000 miles or less.
I have no experience with Amsoil. So I will not comment on it. May decide to play with it in the future.
Fully Built N/A 429. Ten quart capacity.
Mobil One 30 just sucks. It just not good to have a single weight in an aluminum motor. The tolerences are little more than iron blocks and the aluminum blocks expand and contract more. Bottom line, burns oils and goes bad quickly with on/off stop and go driving. A litter higher temp as well.
Mobil One 5-40, 10-40, Pretty good.
Going to get this done in few minutes. The new Improved Mobil One 15-50w, going to use this with a K&N filter. Car currently never gets over 195 degrees(idling or racing(zero heat soak)) with the 10-40. I have ACP vented hood, electric pump, Haltech front screen, cut driver's side molding, etc., etc..
I will report back to forum, after I cook this batch of 15-50w. Should be more difficult.
Grim Reaper is offline   Reply With Quote
Old 04-21-2005, 03:38 PM   #11 (permalink)
redline 5W30......'nuff said.
gasboy is offline   Reply With Quote
Old 04-21-2005, 08:18 PM   #12 (permalink)
15/50 mobil one
Old 04-22-2005, 02:23 AM   #13 (permalink)
vettenuts's Avatar
German Castrol 0W-30. Read the used oil report, great oil especially in an LSX engine.
vettenuts is offline   Reply With Quote
Old 04-22-2005, 11:19 AM   #14 (permalink)
Mobile One 15/50w only way to go!
gorillavet is offline   Reply With Quote
Old 04-22-2005, 12:07 PM   #15 (permalink)
Mobil One, Stock spec. 24K no problems.
D.J.
Autometer Guages, volt, oil temp, oil pressure 2004C5 Member Sales & Want-To-Buy - Parts & Cars 0 08-23-2006 07:39 PM
Oil leak from the oil heat sensor gasket? Z06Perk C5 Z06 - Grandstand 1 12-25-2005 12:26 PM
oil pressure sending unit specs 03 Z06 C5 Z06 - Pit Road 1 06-25-2005 05:53 PM
Synthetic Oil & a magnetic oil drain plug..??? niphilli C5 Z06 - Pit Road 7 04-03-2004 11:40 AM
Has anyone actuly slowed or stopped oil burn by changing weight of oil? SSpray C5 Z06 - Pit Road 12 12-20-2002 10:41 AM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
