Old 05-16-2004, 03:47 PM   #1 (permalink)
Passenger Side Door WIll NOT Lock...
What could cause the passenger side door of my 02Z06 not to lock? It can be manually locked but pushing the lock button on either door does not activate the locking mechanism nor does using the keyfob. Have I programmed it in such a way through the "Configure Options" process to deactivate the passenger side lock or is this dealer worthy?
ANY help or ideas are appreciated - I am stumped....
JKLNHDE is offline   Reply With Quote
Old 05-16-2004, 04:09 PM   #2 (permalink)
This thread might contain your answer
Passenger Door Lock Issue
Old 05-16-2004, 05:38 PM   #3 (permalink)
I've always found lucily by disconnecting the battery a few minutes and reconnect it resets/clears some bug that may be in the system. This should clear any computer probems unless you have other problems.
I always try to use the easiest methods first on these cars because of the vast computerization they rely on.
Good luck and check out "SEARCH" on the above header you might find your probem there.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 05-18-2004, 12:53 PM   #4 (permalink)
spdrcrj's Avatar
theres a TSB out on this. The dealer will replace both mechanisims for the driver and passenger side. I had this done recently.
Old 05-19-2004, 07:52 AM   #5 (permalink)
I was not aware that this problem was so widespread or that there was a TSB on it. Can someone post a copy of the TSB or direct me to a place where I can read/print it? Thanks.
Old 06-26-2004, 08:24 PM   #6 (permalink)
JtownZ06's Avatar
Mine started doing that today. Can't lock the door with the fob, or by driving, only manually. Where can I find the TSB that you guys are talking about??
JtownZ06 is offline   Reply With Quote
Old 06-27-2004, 09:15 AM   #7 (permalink)
Same problem here!
01 Z06 TR/BL
11.70@ 121.09mph 1.652 60'
5900+D/A 410rwhp 380rwtq
SlowZ06 is offline   Reply With Quote
Old 06-27-2004, 09:48 AM   #8 (permalink)
Banned
My driver's side has been intermittant for a month now. I unwittingly left my door unlocked a couple times before I figured out it was happening. I'm going to ask the dealership to look at it. The TSB number would be good to have if someone has it.
SteveZ06 is offline   Reply With Quote
Old 06-27-2004, 09:52 AM   #9 (permalink)
Send a message via AIM to Birddog-Singer
I had that problem with my driver door... I took it back to Chevy and they replaced my door module. Problem fixed!
NCM Member# 23402
I "HAD" a 2003 Z with aTwin-cone intake*Air Bridge*Silicone couplers*acrylic intake plate*Coolant Bypass*CAGS*SLP Headers*X-Pipe*7000 Kel Zenon HID Headlamps * Sequential flashing taillights *XM Radio*
Birddog-Singer is offline   Reply With Quote
Old 06-27-2004, 04:35 PM   #10 (permalink)
Same problem here.
Juan Gonzalez is offline   Reply With Quote
02 Z06/Passenger Door Lock won't unlock vntperformance C5 Z06 - Grandstand 21 12-12-2006 12:35 PM
Passenger door won't lock... ROSSO Z C5 Z06 - Pit Road 16 10-31-2004 07:24 PM
Passenger window and door lock inop... BigGunZ C5 Z06 - Pit Road 0 09-25-2004 02:43 PM
Passenger side lock problem A-Bahn Vette C5 Z06 - Pit Road 1 09-09-2004 08:08 PM
Passenger Door Lock Issue 1stVette C5 Z06 - Pit Road 14 01-07-2004 02:19 PM
