Interested in the new Pontiac G8? Visit the Pontiac G8 Forum @ G8forum.com!
» Tire Upgrade Garage
Register Home Forums Gallery Active Topics Search Today's Posts Mark Forums Read
Old 04-26-2008, 01:20 PM   #1 (permalink)
Pfadt C5 Super Stock Sway Bar Kit
Does anyone know what how the stiffness of this bar compares to the stock C5 Z06 bar?
I would like an adjustable bar that can be set close to the stock bar settings.
2004 Z06 Autocross, HPDE
Autoxer is offline   Reply With Quote
Old 04-28-2008, 08:26 AM   #2 (permalink)
Josh's Avatar
Pfadt SS Sway bar Package
The Pfadt SS Sway bar Package is about 10% stiffer then the C5 Z06 front bar. This package only includes the front bar so it is legal for SCCA's SS class.
The range of adjustment for this bar is from 30% softer to 50% stiffer then the C5 Z06 bar.
We have had a few people running these bars in Super Stock in their C5 Z06 with great success!
Please do not hesitate to give us a call if you have any questions!
Josh@pfadtracing.com
Pfadt Race Engineering
888-972-2464
1525 S Gladiola St
Unit #1
Salt Lake City, UT 84104
Josh is offline   Reply With Quote
Old 05-08-2008, 10:38 AM   #3 (permalink)
froggy47's Avatar
Re: Pfadt C5 Super Stock Sway Bar Kit
I looked at the bar picture on Pfadt site & I'd like a bit more explanation on how the adjustment works.
My (limited) experience with sway bars is that that you vary the stiffness of the bar with the size & material that the bar is made of.
Then you use the adj. end links (after setting ride height & corner weight) to make sure there is no pre load on the bar.
It appears that your adjustment is to preload/unload the bar.
This would change your corner weights & (possibly) ride height.
Is that correct or have I got it all wrong?
Thanks.
1996 LT4 Coupe
2004 Z06/Z16
Old 05-08-2008, 04:47 PM   #4 (permalink)
Does anyone know how the Pfadt Super Stock bar compares in stiffness to the Adco 32mm hollow bar?
Old 05-08-2008, 05:49 PM   #5 (permalink)
Edit: never mind
weirdpanda is online now   Reply With Quote
Old 05-09-2008, 06:41 AM   #6 (permalink)
Thanks.
I was going to enter an explanation of the effects of a lever arm, but the sway bar entry from wikipedia does a pretty good job. Excerpted:
A sway bar is usually a torsional spring that resists body roll motions. It is usually constructed out of a U-shaped piece of steel that connects to the body at two points, and at the left and right sides of the suspension. If the left and right wheels move together, the bar just rotates about its mounting points and does not bend. If the wheels move relative to each other, the bar is forced to twist.
The bar resists the bending through its stiffness. The stiffness of an anti-roll bar is based on the fourth power of its diameter, the stiffness of the material, the inverse of the length of the lever arms (i.e., the shorter the lever arm, the stiffer the bar), the geometry of the mounting points, and the rigidity of the bar's mounting points. Some anti-roll bars, particularly those intended for use in auto racing, are adjustable, allowing their stiffness to be altered by increasing or reducing the length of the lever arms. This permits the roll stiffness to be tuned for different situations without replacing the entire bar. The stiffer the bar, the more force required to move the left and right wheels relative to each other. This increases the amount of force required to make the body roll.
Al Chan
2003 Z06
acrace is offline   Reply With Quote
Old 05-09-2008, 12:46 PM   #7 (permalink)
froggy47's Avatar
OK.
So you change the LENGTH of the end links to make the bar stiffer/or less stiff in a typical adj bar.
Looking at the Pfadt bar, it looks like the link SLIDES to & away from the center of the bar. So it increases/decreases the overall length of the bar. Is that correct (Pfadt vendor?)
Old 05-12-2008, 07:51 AM   #8 (permalink)
Josh's Avatar
The end links are adjustable length so that you can easily remove any pre-load from the sway bar. The stiffness or rate of the sway bar is adjusted by moving the end link mounting point on the sway bar. There are three holes on the front and four holes on the rear to choose from. As the end link is moved from the inside towards the end of the aluminum arm the sway bar becomes softer.
Please let me know if there is anything else I can do to help.
Hotchkis vs stock '01 sway bars itry2hide C5 Z06 - Pit Road 12 10-02-2007 04:39 PM
FS:2005 SCCA Super Stock National Champion Z06 Z06Tig Member Sales - Parts & Cars 2 10-22-2005 11:31 AM
WTB Stock Z06 Sway Bars with End Links Mike I. Member Sales - Parts & Cars 4 06-27-2005 05:44 AM
Can T1 sway bars be used with stock end links?? Silver Bullet Racing 4 11-19-2004 04:52 PM
Stock sway bar question Steve Wright C5 Z06 - Pit Road 1 01-03-2003 02:07 PM
