Old 09-17-2004, 07:01 AM   #1 (permalink)
Proper way to jack up a Z06?
What is the Proper way to jack up a Z06? I have the "pucks". Will I need to put wood under the tires to rase the car first?
1701vette is offline   Reply With Quote
Old 09-17-2004, 09:12 AM   #2 (permalink)
bigbadbevo's Avatar
I know you said you had pucks but use this method, it works well...
http://www.z06vette.com/diy_lift.php
bigbadbevo is offline   Reply With Quote
Old 09-17-2004, 09:58 AM   #3 (permalink)
DJWorm's Avatar
Here is a second method:
1. Locate the triangular steel plate, on a line just behind the outside review mirror and just inboard of the rocker panel underneath the car. This trianguler plate connects the rocker panel frame rail with a steel support that extends inboard to the tunnel underneath the floorboard.
2. Carefully place the jack lift plate under the trianguler plate. Be sure NOT to contact the floor board or the fiberglass rocker panel cover.
3. Slowly jack the car and you will lift both side wheels off, ala NASCAR style.
4. If you are going to be working under the car you can easily place 2 jack stands. Locate the 2 reinforced shipping slots in the frame rail just aft of the front wheel and forward of the rear wheel. Carefully place the jack stands under these points.
You may have to angle the jack stand contact point to clear the fiberglass rocker panel cover.
5. NOTE: If you wish to get all 4 wheels off the ground then you must first drive the opposite side tires up on 2x6's or 2x12's before step #2. This allows clearance for the jack on the second side lift.
I use a low profile racing jack such as the American General from Harbor Freight (at least the 3,000# model) and jack stands from Sears.
No jacking pucks required.
This method is used by almost all the T1 racers and World Challenge racers at the track and in their shops.
AMSOIL Online Store
Old 09-18-2004, 05:00 AM   #4 (permalink)
Thanks DJWorm,
I've been using this method since I read your post a couple of months ago. It saves a lot of time when changing the wheels.
Rudy
rudy oliver is offline   Reply With Quote
Old 09-18-2004, 04:29 PM   #5 (permalink)
Wood depends on the jack you have. You can also grab the aluminum cross members in the center from the front or back.
Proper C6 Z06 breakin SGL C6 Z06 - Grandstand 5 09-16-2006 07:18 PM
FS: AC Hydraulic DK 20Q Jack. Best jack. rwg Member Sales - Parts & Cars 1 03-11-2006 10:49 AM
Proper way to jack up the Z06... chaz704 The Garage 5 10-12-2005 06:01 PM
Proper Z06 Break-In procedures (New Delivery) gaijin C5 Z06 - Grandstand 17 11-03-2002 06:23 AM
Jack be nimble, Jack be quick... RC45 C5 Z06 - Pit Road 9 10-07-2002 07:39 AM
