Question for MTI (stealth cam II) Hearing great things about it but got question 4 U
Hearing great things about the new MTI stealth Cam II.
Will it make 400rwhp in a stock ls6 head Z06 with headers and does it need ls1edit to avoid the P0300 misfire codes.
I think the specs are 224/220 .581 116lsa which helps the idle be a real sleeper. (could be 220/224 .581 116lsa)
Can the new crane dual springs be used? Can the rev 7716 springs be used and which dualies would you recommend if we're not pulling the heads.
Does this MTI stealth Cam as most cams need LS1edit to avoid the P0300 codes at idle..(both with and without a/c running)
Using stock spark plugs
MTI ever try it? Let us know if you could.
Any insight would be appreciated.
JB
