Chevy recommends changing the bolts, however, many, including most racers reuse them. Be sure you clean the threads and apply new Red Loctite if you do. Make sure they are reapplied with the correct Torque specs.
You may discard the clips.
Most rotors today have good quality control. However, as some recommend on this site, if you use cheap $14 rotors I would bet that no one checked them. It all depends on the quality of the rotor.
Turning a rotor is usually not a good thing unless it is to remove a small surface imperfection and is done minimally. A rotors job is to convert kinetic energy to heat and dissipate it. Turning or milling a rotor will remove material and reduces it's ability to do so.
I think however what you are refering to as "truness" is also called "run out". Most rotors are within spec. Some wear to become out of spec. This can be corrected with a Brake Lathe as opposed to a rotor Lathe. A Brake Lathe actually turns the rotor while it is still mounted on the wheel hub. This trues the rotor and brings runout back into spec.
Be aware that run out can be cummulative. ie. All the parts of the wheels such as bearings, hub, spindle, rotor can be within spec but their differences together may add up to produce a cummulative run out, within or outside spec.
One of the most common causes of excessive cummulative run out and misdiagnosed excessive rotor runout is a dirty hub and/or rotor face.
Make sure that you clean and wire brush and sand if necessary all rust, dirt, brake dust and fluids off the mating surfaces before reinstalling a new or used rotor. This must be done each time a rotor is removed. Chevy has a special tool for it.
AMSOIL Online Store
