Raising Front End C5 as opposed to lowering it. - Z06Vette.com - Corvette Z06 Forum
post #1 of 12 (permalink) Old 06-28-2004, 01:46 PM Thread Starter
It may sound strange but is it possible to raise the front end of a C5, about an inch rather then lowering it? Has anyone done it? Would it cause any problems?
Jimmar
jimmar is offline
post #2 of 12 (permalink) Old 06-28-2004, 01:48 PM
Wingnut's Avatar
Has it been raining that much where you live? :pp:
Magnacharger/Longtubes/RandomTech HiFlow Cats/Vortex Rammer/
MGW Knob/Borla 2-Tip Stingers/ShanerS2 TB/OEM Z06 Wheels painted black/polished lips/ACI Hood/Exedy Hyper Single Clutch/Blower Cam/495rwhp/481rwtq/3:90's with hardened output shaft
Wingnut is offline
post #3 of 12 (permalink) Old 06-28-2004, 01:55 PM Thread Starter
It has been raining a lot in Central Florida but I had a supercharger installed and this installation moved the radiator forward and tilted slightly. The center spoiler was moved and trimmed but I'm still bottoming out more then I'd like. Trying to fix this problem.
Jimmar
jimmar is offline
post #4 of 12 (permalink) Old 06-28-2004, 02:00 PM
Wingnut's Avatar
Well that makes sense. I was just ribbing you because I couldn't understand why anyone would raise the front. I'm sure someone will chime in with some help.
Wingnut is offline
post #5 of 12 (permalink) Old 06-28-2004, 02:19 PM
Do the opposite of the "stock lowering" (search lowering)instructions, then align. But, watch the rake or "lift-off".
Zambroski is offline
post #6 of 12 (permalink) Old 06-29-2004, 07:17 AM
You could also lower the rear while leaving the front at stock/max height - that will have the same net effect.
freefall is offline
post #7 of 12 (permalink) Old 06-29-2004, 06:26 PM
CJS
I raised the front of my 2001 C5 by about .5 inch by using 275/40/18 tires and wheels at 26.7" tall on the front. They are about 1" taller than the stock 245/45/17 tires and wheels at 25.7" tall.
I have noticed no ill effects up to 117 mph.
CJS is offline
post #8 of 12 (permalink) Old 06-30-2004, 05:25 AM Thread Starter
We gained about 1/2 - 3/4 of an inch by doing the opposite of lowering i.e. working with the spring bolt. The rake appears to be okay. A brief drive and backing into my driveway was back to the normal slight touch of the spoiler. We'll see how I do on brick paved streets and cobble stones. :-?
Jimmar
jimmar is offline
post #9 of 12 (permalink) Old 07-01-2004, 07:47 PM Thread Starter
Procharger Release Valve Filter - does it matter if it gets wet?
Late this afternoon we had a little torrential downpour. Violent thunder and lighting and a deluge of rain that was like a flash flood falling on you. My wife saw one Corvette in water up to his headlights in the middle of the road.
It wasn't me. With the way my procharger is installed my filter is high in front of the radiator, right under the hood I should be pretty safe. That's the good news. But the blow off filter is low and could get wet, but since it exhales it shouldn't make much diference if it get's wet, should it?
jimmar is offline
post #10 of 12 (permalink) Old 07-01-2004, 08:10 PM
FRC Tom's Avatar
Lowered the rear on my FRC leaving the front stock so my spoiler would stop scraping my drive. Don't let the air get under at high speeds.
It is what it is
Still the Best
FRC Tom is offline
post #11 of 12 (permalink) Old 07-01-2004, 08:24 PM Thread Starter
Those pictures hurt. This happened because air got under the car? How fast were you going?
I have not lowered the rear, in fact because I have 285/40 -18's in the rear instead of the stock tires I'm slightly higher then normal. so even with the slight raising of the front end, the natural rake should be in tack. I guess I'll have to test it and see how I do.
Jimmar
jimmar is offline
post #12 of 12 (permalink) Old 07-01-2004, 10:01 PM
FRC Tom's Avatar
Jimmar
About 110 going through the traps into a 25 mph headwind.
Picked the rearend right off the ground.
That was a 360 with 2 bounces off the guard rail.
It is what it is
Still the Best
FRC Tom is offline
Clunking in front end after lowering Gordo C5 Z06 - Grandstand 5 11-01-2006 08:09 AM
Quick Help on lowering front end! CopMagnet C5 Z06 - Pit Road 1 08-14-2004 12:35 AM
Front end Lowering Problem??? tlaselva C5 Z06 - Pit Road 10 04-12-2004 03:37 PM
Lowering the rear end of a 2001 Z06? blschele C5 Z06 - Pit Road 2 11-04-2002 09:50 PM
Lowering Front End Ernie King C5 Z06 - Pit Road 3 12-12-2001 08:01 AM
