Run flat tires or no for replacement tires? - Z06Vette.com - Corvette Z06 Forum
post #1 of 7 (permalink) Old 08-13-2005, 10:59 AM Thread Starter
briann510's Avatar
I need some rear tires on the car. Places I have called are asking me if i want to go withthe run flat tires. Without this car having a spare it is a viable option I guess to want them.
Big differences in running run flats over non run flats other than peace of mind if i do ge ta flat while a long way from home?
I will be buying the Goodyear Eagle F1's, but not sure if these exact tires actually come in run flats.
Thanks.
briann510 is offline
post #2 of 7 (permalink) Old 08-13-2005, 11:40 AM
You will be adding weight and increasing your rotational inertia. The worse place to put extra weight is on the OD of the tire. Do you have the inflation kit that came with the car? I've never used my kit so I can't comment about it's effectiveness.
Chas.
wlxx861 is offline
post #3 of 7 (permalink) Old 08-13-2005, 12:32 PM
RocketSled's Avatar
The DOT prohibits use of Run Flat tires without a tire pressure warning system. It's a good rule, one that shouldn't be ignored.
The Z has the TPW system, but it is disabled. You'll need help from your local dealer to enable it with their Tech-II scanner, and you'll need to buy sensors for all four wheels.
You don't need to use Run Flat tires to use the sensors, I don't.
The handling properties of the Run Flat tires are a bit different from normal tires due to their much stiffer sidewalls. Personally, I wouldn't mix them with normal tires. Also, the Z mounts a 295 in the rear. As far as I know, the largest Run Flat you can get is a 275, which is smaller than stock (it's the stock size for the Coupe and Vert).
If you want piece of mind, just install the sensors. Tires rarely go flat instantly, they leak slowly. With the sensors, you'll always know how much air is in each tire, and the system will warn you if the tire goes below, I think 24 PSI, so you can just put more air in the tire (your Z comes with an inflator) until you can get repairs.
C6!
RocketSled is offline
post #4 of 7 (permalink) Old 08-13-2005, 12:38 PM
The compromise of ride quality and handling is too much of a trade off IMHO to run the extended mobility tires more commonly known as run flats..they are loud , rough riding and not praticularly good handlilng tires..when compared to the other high performance tire choices available to you..myself I would not even consider a run flat when making a choice on new tires.
Steve Tillman
45 Years Of Corvette Experience
Y2K NBM 6MT HP?\TQ?
It's stock they all sound like that
Steve Tillman is offline
post #5 of 7 (permalink) Old 08-13-2005, 01:37 PM Thread Starter
briann510's Avatar
Thanks everyone. The replies were just what I needed in information as to NOT run them.
2003 Z06 with A&A Vortech V-2 T-Trim package at 8 psi
post #6 of 7 (permalink) Old 08-15-2005, 10:38 PM
Wise choice. You're better off not running them. More cons than pros.
Alex
Recent: 2003 Z06 BLK/BLK/BLK - GHL Exhaust | Zip-Tie Intake | NGK TR 55s | Nitto 555 RIIs. My BPP Shifter Broke In Two!!
ZO6 AL-X is offline
post #7 of 7 (permalink) Old 08-16-2005, 04:25 AM
Speedratchet's Avatar
Location: San Angelo, Texas, Z06 Fest Member V, VI and WinterFest I, II
Good decision.
Speedratchet is offline
Poll: Replacement Tires Zippy Z06Vette Polls 123 08-01-2013 10:46 AM
Anyone running Run Flat Front and Non-run Flat rears? Kirch C5 Z06 - Pit Road 2 05-11-2006 08:40 AM
An Interesting Note On Run-Flat Tires DavidNJ C6 Z06 - Pit Road 5 03-15-2005 11:48 PM
F/S 2004 C5 painted rims and run flat tires NEW!! OpticZ06 Member Sales/Trades - Parts & Cars 1 02-05-2004 04:07 PM
Hints on flat spot tires? mvette C5 Z06 - Pit Road 2 02-11-2002 02:27 PM
