Old 07-29-2001, 04:05 PM   #1 (permalink)
teamzr1
Posts: n/a
Some of us teammates local to Sears Point Raceway spent about half a day there to do some testing on the drag strip.
For me it was to test that in fact going with larger injectors could be dialed in with the use of a MAF translator and my IATuner circuit as to airflow, fuel trims, timing and knock.
My goal with these test runs was to better the timing for better off the line launches which have almost always been 2.2. to 2.4 seconds 60 feet times.
Check this team webpage for a gear by gear blow results of the 3 runs made.
http://teamzr1.com/drag728.html
First run, I was the first car off the line, at about 8 AM, no sun, about 55 degrees and they just had sprayed the track so it was too slick.
2nd and 3rd runs the sun had come out and temp was about 85 degrees.
All three runs now had 2.0 60 foot times and I made tuning changes using MAFT and IATuner to test differences to rich/lean conditions and knock.
Not one run had any knocks (which is a first for my drag runs), ZERO, thus it proved that at least in my '99, carbon, and the other reasons for knock were either not the cause and or could be adjusted out altogether.
Topend speed ( 66 feet past finish line)
was 119, 122 and 124 MPH, thus tuning clearly dicates performance.
I made tuning changes prior to leaving for the track knowing since the track is over 100 miles from my home that by the time I got there the PCM would have readjusted for my forced changes.
To assure knock could be dialed out, when I got to the track I made changes to air/fuel and timing, made a run and then adjusted again to prove knock could be dial out in a repeatable manner.
I left the last tuning changes as they were after last run and drove the 100 miles back home and monitored the PCM during the drive to see what the PCM would do over mileage.
I can see why one hardwired resister in place of the IAT sensor is not a good path over time and will oontinue to adjust IAT with the way my IATuner functions.
You can see all the results related to all this mod tuning on team forum.
_________________
'99 Mallett 450 MN6
Best time slip: 12.5 at 120 MPH - 60 Foot at 1.9 using street tires
http://teamzr1.com
Old 07-29-2001, 05:43 PM   #2 (permalink)
Teamzr1
As ive posted before, keep it up its post like yours that make this a great Learning site.........
Old 07-29-2001, 07:49 PM   #3 (permalink)
Keep the info coming, This is what makes the men from the boys. Are you using Diacom or someother software to montior everything? do you have the pin outs of the AGLC? plug? So I could just wire it in to my laptop.
thanks for the info
02 Bad Blue Z06
BADASSZ06 is offline   Reply With Quote
Old 07-29-2001, 08:07 PM   #4 (permalink)
teamzr1
Posts: n/a
On 2001-07-29 19:43, IMA Z06 spewed forth this drivel:
<B>Teamzr1
IMA Z06,
I've donated Corvette websites, 2 Corvette e-mail systems and a forum since 1995 for I firmly think we all should use cyberspace to exchange what we learn or experience 1st hand in owning a Corvette to share our knowledge can only be helpful in increasing the joy factor of owning America's only sport car.
John
</B>
Old 07-29-2001, 08:11 PM   #5 (permalink)
teamzr1
Posts: n/a
On 2001-07-29 21:49, BADASSZ06 spewed forth this drivel:
thanks for the info
I use Daicom on C4s, it will not work on C5s.
The only one that does is called Autptap, it's not very good but better then nothing.
The traces you saw in my post above was using that and then I import it on Excel to get it in the form you see it.
You can review this PCM diag tool at:
[url]http://autotap.com]/url]
If you get it and want to ramp up your learning curve in using it, feel free to e-mail me.
John
Old 07-29-2001, 08:22 PM   #6 (permalink)
Thanks John, Before I start adding stuff to my Z06 I want to make sure its correct to begin with. Knock etc.. Thanks for the info, I also found a tool called The PROGRAM. have you heard of it?
Jason
Old 07-29-2001, 08:54 PM   #7 (permalink)
teamzr1
Posts: n/a
Jason,
Never used or heard of that program.
Autotap is the only well known one that is used my many Corvette owners and thus by you also using it you then have a better chance of being able to e-mail those owners yuor traces and also run those traces in autotap and helping review how your PCM and then functions it controls.
The more you monitor the PCM, the more you know exactly what is going on and when any changes have ocurred or degraded.
John
Performance with mods and stock tuning? WayneE C5 Z06 - Tuning & Electronics 10 02-22-2004 03:38 PM
Does It MAKE A DIFFERENCE??? TexasBlue72 The Garage 6 02-02-2004 03:14 PM
Wideband tuning with cats? How much of a difference does it make? vortech C5 Z06 - Tuning & Electronics 12 07-22-2003 11:24 AM
What is the difference between all the different tuning products? 427l C5 Z06 - Tuning & Electronics 2 06-12-2003 11:35 AM
What a difference 30 years make.................. rossvette The Garage 9 02-09-2003 04:14 AM
