Old 04-04-2005, 12:23 AM   #1 (permalink)
Serious advice needed about my Z
Well, I had problems with my harmonic balancer pulley spinning off. I figured maybe the pulley was bad or the bolt came out from being seated properly. After digging in to it today and getting the pulley off and the bolt out, I noticed the pulley was pretty eaten up. I felt the crank shaft and can feel grooves cut into it from the pulley spinning on it. I have ASP pulleys waiting to be installed, but I stopped to seek advice...
I was told by a friend that the crank shaft is ruined due to the grooves and that a pressure fitted pulley (as we have), will not seat properly in a grooved shaft. Since our crank shafts are not keyed, he says the pulley will not seat and will just spin and get ruined like the old one.
First off, I have no idea how this happened as the car only has 7,200 miles, but I bought it used and the guy I got it from had lots of stuff done to the engine. I figure they did not seat the bolt properly and time caused it to come off.
Advice...has this happened to anyone else? Is there any way to make the pulley stay without having to pull the crank shaft and getting a new one? I was told I can try to smooth it out with an emery cloth or fine sand paper and then use a sleeve on it. Do they even make sleeves that will work with our cars? Am I just totally screwed and have to get a shop pull the crank shaft? My buddies are pretty car savvy...what are the chances a garage mechanic can get the crank shaft out? Is there anyway to key a crank shaft without having to remove it?
Lots of questions, yes, but I need answers to figure out which road to take from here.
Thanks...feel free to email me at rodrigo.cantu@usmc.mil
Rodrigo
SPDKLZ is offline   Reply With Quote
Old 04-04-2005, 01:14 AM   #2 (permalink)
ATI I believe or maybe its ASP makes a pin kit for it, it comes with the magnacharger.
01 Z06 TR
98 Z28 Vert few mods
01Z06Wicked1 is offline   Reply With Quote
Old 04-04-2005, 02:04 AM   #3 (permalink)
Can I key the crankshaft without removing it from the motor?
Old 04-04-2005, 05:58 AM   #4 (permalink)
holedgr's Avatar
Location: Where I have to be when I am not at a Z06Fest
Yes, you can drill and key the crank without pulling the engine....is there too much damage?? I can't make that call. I suggest VERY HIGH resolution pics sent to Andy at A & A or one of the many supporting vendors to ask their opinion. I would call before just emailing them though. Do a search on keying the crank here and I'd bet my life you'll find all the info you need!!
-Tony
holedgr is offline   Reply With Quote
Old 04-04-2005, 06:06 AM   #5 (permalink)
Super Moderator
mdickie's Avatar
Send a message via AIM to mdickie Send a message via MSN to mdickie
Send an email to AntiVenom (Greg), I am sure he could help you understand your options.
Mark
"Civilized until it is time not to be civilized"
mdickie is offline   Reply With Quote
Tires and Brake Pads Needed. Advice Needed! speedy41 C5 Z06 - Pit Road 16 08-13-2006 11:30 AM
Advice needed LoneRegister C5 Z06 - Grandstand 22 05-18-2006 10:51 PM
Please Help - Restraint Advice Needed BQuicksilver Racing 2 07-19-2005 03:44 AM
Help Advice needed japon C5 Z06 - Grandstand 14 03-08-2004 08:14 AM
advice needed FLYINGZO6 C5 Z06 - Grandstand 5 02-14-2002 02:07 PM
