this has happened before but just went away after a restart. This time I was driving along accelerating hard and hit a bump in the road. Large bump but nothing crazy by any means. All of a sudden the DIC started flashing those messages. Upon restart the same thing. I reseted them away and they just come back upon startup. clearly the active h button does nothing now. Anything I can do before bringing it to the dealer?
06 Z06 Black/Black/Black/Black 1LZ-U3U-RC8 Mods: Exhaust switch - Bondurant Driving School - 345 Pilot Sports - Vette Doctors Air Charger - Tune =489rwhp 461rwtq 11.240 @ 128.5 w/ terrible 1.856 60' --- 03 Z06-EB/ModRed..traded in. Others:96 Grand Sport coupe #451-71 Vega 900hp 1800lbs
I don't know, but mine is doing the same thing, but I thought it was because I had the steering column lock done and then went back to Dragon Eng. and had 'em put my old tune in. :oo:
If you find out let me know, Please!!
Peelin' Out
Ted
Born on Date-10-12-01, MCM Hood, ACI Front Spoiler,Caravaggio Rear Spoiler, Kooks 1 3/4 LT,Vortex CAI Stingers, Hurst Shifter /Flameball, EE Tunnel Plate, RD Harness Bar/5 point harness, V-1 and Cobra 75 CB
I had the same codes pop up twice, once in the summer just driving done the road and then about 2 months ago. I have an appointment with the dealer on the 29th but am worried about losing my tune... I also just noticed that my drivers' side wheel is slightly out of the wheel well and the passenger side is not. Don't know what that could be!!!
Like stated before, there can be loose connectors such as the wheel sensors. Check the sensors at the ABS module and the module that controls the TC/AH/ABS.
There can be a short somewhere that can be causing a misread.
What can happen unfortunately (like in mine) was that a short in a wire fried my ABS unit and the module/computer that controls the TC/AH/ABS and it all had to be replaced. Make sure its all covered under warranty just in case...its all really expensive stuff!!!
Good luck
__________________ 2003 Black-Black Z06
2003 Sonic Blue Cobra #257 516rwhp *Sold* l 2002 EB Z06 445rwhp *Sold* l 2000 Black Camaro SS 440rwhp *Sold*
Location: Gilbert, AZ Z06 Fest II,III,IV,V WinterFest 1&2
You may have some wires chafing going to the TAC module!
I had intermittent 'go into limp mode' problems on mine after the wreck! AH TC not available, reduced engine power!!!
The TAC module had some wires that were chafing against the PCM and the shorting toasted the TAC module!!
It's the black box just in front of the PCM in the space behind the panel in the wheel well behind the right front tire!!
I had the same problem (all 3 messages coming on) and I had the C1214 code....It turned out to be the EBCM(electronic brake control module),it is covered under warranty 3/36...
I have seen the wheel sensor wires get heat damaged by headers before, short out and cause this.
Ah geez, I'm already not sure if the dealership I have appointment with is "mod friendly" and now you had to go and say something like this. Anybody want to bet that they'll say I'm responsible for the cost of the units that have been mentioned above. Oh well, it's still going in to let them have a look. Very anxious now though, first time in since pickup, which I did in Ohio. That dealership was alot different than the stories I hear of locals around here.
That trio of error messages is back on my car too now....had it a few times in the past but it would go away upon restart. Now its stayed for the last three days so I took it in, as of right now they say they have to replace a module, which costs about a grand....thank goodness I have a service plan with my dealership...all I pay is a 200 deductible on everything covered by GMPP or something like that.
It is the EBCM(brake module).You are correct it about$1000 Thank god for the extended warranty
Shop Foreman
ASE Master Tech
L1 Certified
Just when you're feeling outside in the cold, a friend pops in and gives you a good feeling!!! Bobby, give me a call if you get a chance. Popeye said you were the man!! My baby's in your hands!! First time she's has been in! Thanks bro!!
