Old 03-24-2009, 07:29 PM   #1 (permalink)
Shifter
Hey I was wondering if there was a T grip shifter for our vettes.. I would like to shorten the throws in my shifter along with adding a new T grip to the combo. Thanks guys.
BTW I have an 03 z06 The faster yellow color haha
03 Z06
It never was so sweet!!
STOCK (Soon to be changed!!)
Soon to installed
9 piece Black out kit
Hurst short throw shifter and handle
Slp/bullet exhaust (still deciding...)
blackwing cold air intake
Luke01 is offline   Reply With Quote
Old 03-24-2009, 07:44 PM   #2 (permalink)
DennyM's Avatar
Re: Shifter
Welcome to
You looking for an aftermarket shifter or shortening the shaft on your OE shifter?
I've seen Tee grips ... so I know they're around ... but I'd think that first you gotta figure out what you're attaching it to.
Old 03-24-2009, 07:50 PM   #3 (permalink)
Re: Shifter
Im looking for an aftermarket B&M kinda thing. Swaping out stock parts for the better stuff. I wanna connect the T grip to what ever is the best. (If all goes as planned im gonna do a couple serious mods)
Old 03-24-2009, 08:54 PM   #4 (permalink)
MikesZ06's Avatar
Re: Shifter
Yes, I used a Hurst T-grip on my C5Z for a while.
You have to rethread the shifter though. No big deal.
(I took it off after a while because the grip just got too damn hot after a couple of passes at the strip from engine heat.)
Vette Magazine article
1/4 mile pass
Old 03-25-2009, 01:36 PM   #5 (permalink)
Re: Shifter
My recommendation is the Hurst shifter with A C5R Delrin shift knob from Hardbar. The Hardbar knob can be drilled to make it sit even lower on the shifter for even shorter throws. It comes in a regular or "Chubby" size.
I prefer the Hurst shifter as it has adjustable Stops.
The OEM shift pattern fits over the cigarette lighter if you have Alzheimer's.
Old 03-25-2009, 04:48 PM   #6 (permalink)
Mark Olson's Avatar
Re: Shifter
I'v been using a moded B&M. How is it'moded? One of the first things I did was to alter the springs that control self centering, the B&M heavy on the 1-2 side, and a lighter (about 1/10 the spring rate) on the 5-6 gate. What this did was make 3 gear shifts almost automatic, and the 5-6 shift with the same wight of the stock shifter, It also makes down shifts more presice (for me anyway). Next mode was to take a stock shifer leaver and turn down the B&M leaver to accomadate the rubber of the stock unit to fit (no rattles) and some lenth, on top of that I use a touring car (momo brand, that has been in all three of my Corvette's). Having the longer leaver, with the short throughs of the B&M is that the hand movement from the steering wheel to shifter is on a level line, and the throughs are still 30% shorter then the stock leaver, with a very direct feel.
I have a box full of other knobs but I keep coming back to the Momo DTM, the last on was a Hurst ball type, but the locking nut was causing problems with it's sharp edges.
My 2 cents on a short T type, would be uncomfortable in it's movement, it's not like a sedan floor shifter, like say my 65 Mustang. (I would install the T handle when running at Wed grudge races, and it was a four speed).
Mark.
Old 04-03-2009, 12:46 PM   #7 (permalink)
Re: Shifter
I got a traditional T-handle several years ago from MGW that was standard threaded. I also had their "Gripper" knob, and ended up going back to that one over the T. I gave both knobs away when I sold my BPP shifter (stupid) to try the C6Z one. Probably will eventually get the MGW shifter, and stick with the C6 knob, which I really like.
''Go ahead, freak out the neighbors!"
exSSer is offline   Reply With Quote
Old 04-03-2009, 01:02 PM   #8 (permalink)
BigJimZ16's Avatar
Send a message via ICQ to BigJimZ16 Send a message via AIM to BigJimZ16
Re: Shifter
I put the Hurst on a couple of weeks ago along with the Hurst "ball" knob. Huge improvement over the stock, the 2-3 is almost automatic!!! I had one problem though, after a couple of days of driving the stop for 1-3-5-R locknut came off and the stopscrew started to limit shifter travel to the point where all I had was 2-4-6!! Note to self: read directions all the way through, don't stop because it says "OPTIONAL - CAUTION". That's where it tells you that if you're not going to utilize the stops, REMOVE THEM!!! Fortunatly no damage, just damp shorts...
The only thing you get when you make something idiot proof, is a better grade of idiot
Z06/Z16 #1689 of 2025
BigJimZ16 is offline   Reply With Quote
Old 04-04-2009, 07:17 AM   #9 (permalink)
MikesZ06's Avatar
Re: Shifter
Mark.
Mark, I didn't find the Hurst T shifter uncomfortable in it's use, but that sucker got hotter than a pistol at the dragstrip after a pass or two.
Shifter Boot for Hurst Shifter --> H20Vette C5 Z06 - Pit Road 2 08-22-2005 08:43 AM
Stock shifter / Breathless shifter Grant P C5 Z06 - Pit Road 7 04-14-2003 02:30 PM
shifter knob for hurst shifter zul8r C5 Z06 - Pit Road 6 09-03-2002 10:36 AM
Hurst Shifter update, install link and comparison to other shifter - 3/4/02 RG Vendor Sales - C5 3 03-04-2002 08:34 PM
Kirban shifter vs B&M Ripper. The winning shifter is on sale Nate @ CorvetteGarage Vendor Sales - C5 15 04-21-2001 06:33 AM
» Latest Auto News
Lingenfelter Cadillac CTS-V Tuned to 630-Horsepower
Years ago Cadillac was strictly geared towards an “older”
Tanner Foust Drifts Mulholland Drive In NASCAR V8-Powered Scion tC [Video]
We’re not even sure why we’re writing any copy. The video
Report: Mercedes to Eliminate Maybach Brand by 2014
Resurrected in 2002 as a way for Mercedes to take on rival
» New Car Reviews
2010 Nissan Sentra 2.0 S
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
