so there was this oil spot...
Lets start from the beginning. I bought an ASP UDP for my 2002 Z06. It was put on about 1000 miles ago and one day on my way home from work i noticed this belt squeal. No big deal right? Maybe some belt dressing, clean it, or worst case buy a new belt. After i sprayed and cleaned it the sqeal was still there so I decided to get a new belt put on.
The next day when i left my garage to take the vette to the shop i noticed an oil spot on the floor...... I get a phone call from the tech later on saying that the pulley is whobbling and created the front main seal to break loose or something.
2 questions:
Did this happen because it was installed wrong?
What could all be wrong? I'm hoping the crank and block are ok!
2002 Electron Blue Z06
Cartek 2x heads & cam, Spec 3 clutch, Kooks LT's, Kooks Xpipe, Corsa catback, Vararam, Short Throw Shifter, 555r 335, front/rear sway bars, AIR*
