Old 09-26-2003, 08:44 PM   #1 (permalink)
squeeky breaks !!!!!!!!!!
ok guys lets have it
my z is 1 year young w/3500 easy miles.
never raced on the track and just driven
weekends.however everytime just about when i'm ready stop it starts SQUEEK.
i tried hiting them hard foward and reverse, no better. does the car need harder miles or do i have to live with it?
i really dont want to replace the new pads
HELP...
thx joe
bluethunder is offline   Reply With Quote
Old 09-26-2003, 09:02 PM   #2 (permalink)
This is usually caused by the pads becoming glazed. To get rid of this drive normally for a while to warm up the brakes then do a couple moderately hard decellerations from about 70 down to around 10-15 mph, but don't stop or engage the ABS.
It can also be caused by some contamination on the rotors but it's unlikely.
Old 09-26-2003, 09:10 PM   #3 (permalink)
Send a message via AIM to Andy Cravens Send a message via MSN to Andy Cravens Send a message via Yahoo to Andy Cravens
My Z06 did this and I heard it was completely normal due to the Z06's soft brake pad compound.
Andy Cravens is offline   Reply With Quote
Old 09-26-2003, 09:17 PM   #4 (permalink)
Some pad compounds tend to glaze more than others, with more aggressive pads being more prone to it, yes. 'Normal' is a relative thing.
That said the only way to really eliminate it for long is to change to a more streetable pad. Many people, myself included, prefer using ceramic compound pads on the street as there is virtually no dust or noise.
Old 10-01-2003, 06:56 PM   #5 (permalink)
thanks a bunch
i'll try it this weekend
Old 10-02-2003, 01:33 PM   #6 (permalink)
DJWorm's Avatar
You need to rebed the pads as was said above: 2-3 hard stops from 70 to 10 MPH in rapid sequence after warming the pads/system up...... then let it cool over night.
Old 10-02-2003, 01:55 PM   #7 (permalink)
Can a person autocross (competitively) w/ ceramic / more streetable pad? Not highjacking this thread - I am getting the squeaking since last weekend's fun too... thx...
DarkHelmet is offline   Reply With Quote
Old 10-02-2003, 02:02 PM   #8 (permalink)
You could but you probably wouldn't want to. Reason being the ceramic pads are more prone to fade under repeated hard braking and you might end up with no brakes at some point.
You're better off using seperate pads and rotors for AutoX or track. You get the best of both worlds that way.
Old 10-02-2003, 02:22 PM   #9 (permalink)
thx No Doubt - I had read that elsewhere here but wonder about the monthly "jack the car up, and .....". I need to consider my potential level of ongoing involvement... thx again.
Old 10-03-2003, 02:10 PM   #10 (permalink)
Send a message via AIM to KillerCobra42
I talked with a few people about it. They said in 02 they used a harder brake pad for better stopping, but under low speeds it will squeel. My 02 does it and it has 14k miles on it.
KillerCobra42 is offline   Reply With Quote
Old 10-04-2003, 10:32 AM   #11 (permalink)
DJWorm's Avatar
I use KFP Gold pads for AutoX, Pro Solo, that have great stopping ability, coefficient of friction, run relatively cool, have a broad heat range are ready immediately and have a great release and modulation plus have ceramic backing plates. They are a carbon/Kevlar composition and are rotor friendly. i iuse them with OEM cryo'd rotors and have moderate dusting and no squeaks.
If I do pick up a squeack I just rebed them immediately.
Old 10-04-2003, 07:38 PM   #12 (permalink)
spdrcrj's Avatar
I received a quick reference "hanger" type pamphlet with my car. It's from GM and it says you should expect higher than normal brake dust and squealing at low speeds due to the front brake pad material. The squeal you hear is normal for our "race cars with license plates".
Squeeky Center Console BradCZ06 C5 Z06 - Pit Road 1 02-03-2005 12:45 PM
Squeeky wheel gets the ??? Z06Y Lady C5 Z06 - Pit Road 3 03-30-2003 08:32 PM
Anyone else have Squeeky Brakes? Scott & Sharon C5 Z06 - Pit Road 20 01-23-2003 09:10 PM
squeeky brakes bluethunder C5 Z06 - Grandstand 3 11-05-2002 01:55 PM
Bleeding Breaks? ELF Z06 C5 Z06 - Pit Road 2 10-22-2001 09:22 AM
