Old 08-23-2005, 10:09 PM   #1 (permalink)
Steering wheel noise
Lately when I've been parking or throwing a U-turn, my steering wheel has been making squealing noise. When I turn it hard left or right, it almost sounds like it's crying .
Any ideas on whats this could be? A friend of mine told me it could be a bearing.
Old 08-23-2005, 10:38 PM   #2 (permalink)
Send a message via AIM to prospero63 Send a message via Yahoo to prospero63
You sure it's not the tires? Sometimes mine do that (especially in the parking garage at work). The other thing to check is to make sure you don't cut the wheel all the way one way or the other. When you do that it puts more pressure on the power steering hoses and such and can make a whine. Take the wheel back a few degrees. Car will turn just as sharp, but without the pressure buildup.
"Let me explain how the chain of command works. I take this here chain, and I beat you until you obey my commands."
Hardening Network Infrastructure
prospero63 is offline   Reply With Quote
Old 08-24-2005, 08:02 PM   #3 (permalink)
I definitely know it's not coming from the tires. It's coming from the steering column.
Old 08-24-2005, 08:13 PM   #4 (permalink)
Speedratchet's Avatar
Does it sound like it's coming from the power steering pump?
Visit me at: Speedratchet
Old 08-25-2005, 04:57 PM   #5 (permalink)
I have the same problem. It's coming from the steering column.
On the corvetteforum.com they metion putting in Lithiium grease in the steering wheel bearing. Not sure how to get to it. I'm going to have to check this out more.
Your not the only one.
Steve
mountainbiker2 is offline   Reply With Quote
Old 08-25-2005, 07:06 PM   #6 (permalink)
Steve
A friend of mine told me that it might be the upper steering wheel bearing.
Let me know what you find out.
Old 08-26-2005, 03:15 AM   #7 (permalink)
Vette Doctor
c4c5specialist's Avatar
HI there,
Another solution to the steering bearing at the bottom of the column, is Dry release lubricant.
It is made by 3M and can be sprayed in and it will penetrate.
However, it is very difficult to get to.
Its only 2 pieces of plastic rotating together.
Allthebest, c4c5
Old 08-26-2005, 08:13 PM   #8 (permalink)
So how exactly do I get to it?
Old 10-16-2005, 10:40 AM   #9 (permalink)
smook's Avatar
I'm getting this issue on a new 2004 Z06 CE (1275km only!)
What's up ? Anyone ? Is there a TSB on it?
smook is offline   Reply With Quote
Old 10-16-2005, 01:16 PM   #10 (permalink)
RocketSled's Avatar
Remove the screws from the back of the steering wheel hub and the horn/airbag assembly lifts off the front of the wheel. Disconnect the yellow airbag wire. There's a big nut and a couple of snap rings that have to be removed and the steering wheel will pull off. Under the wheel is a big donut-ish shaped thing, the steering wheel angle sensor. It just slides off the wheel shaft. It's keyed so it'll only go back on one way. The bearing is exposed beneath that sensor.
Start with the wheels straight the the steering wheel level so when you put it all back together the steering wheel will still be centered.
C6!
Old 10-16-2005, 01:53 PM   #11 (permalink)
Z06phile's Avatar
Location: South AL/// Z06 Fest Participant I II III IV V VI VII
Mine was doing the same thing about 3 years ago and the pic shows the spot the squeaking/rubbing sound was coming from.
c4c5specialist told me to spray some white lithium in there and it worked. No need in taking things apart, just pop the hood and it's right there.
'01 Z06 Lingenfelter 383 Stroker w/ all the bolt-ons, braced DTE 3.90, Pfadt coil overs, Stoptech BBK, 18/19 iForged Aero
'04 CTS-V Hotchkis ARBs
'08 Honda S2000 CR daily driver
Z06phile is offline   Reply With Quote
Old 10-17-2005, 06:46 PM   #12 (permalink)
Thanks for the tips. I'll give these a try.
Steve
99 FRC
402rwhp. 380rwtq.
Pic too tall..please resize to site specs
Old 10-17-2005, 08:31 PM   #13 (permalink)
Thanks guys, Ill let you know if this helps.
One other question: My buddy told just to spray some silicone in there. Will this help?
Old 10-18-2005, 07:39 PM   #14 (permalink)
Check this out.http://www.corvetteforum.com/techtip...D=35&TopicID=1
mvvette97 is offline   Reply With Quote
How much steering wheel play is normal? Anyone wear their steering rack? Cobra4B Racing 18 03-06-2006 03:24 PM
Rattling noise around steering column sdirsche C5 Z06 - Pit Road 0 10-12-2005 05:48 PM
Steering wheel hub size? (Aftermarket steering wheel) RyanZ06 Racing 0 11-22-2004 05:43 PM
power steering makes noise robiferretti Racing 4 07-14-2003 06:49 AM
Help! Noise coming from steering wheel. Z06phile C5 Z06 - Pit Road 12 10-08-2002 09:33 PM
