I believe these numbers to be correct:
Base:
Front 23mm, 3.81mm wall thickness
Rear 19.1mm, 2mm wall thickness
Z51: (00 and up)
Front 28.6mm, 4.15mm wall thickness
Rear 23.6mm, 3mm wall thickness
Z06:
Front 30mm diameter, 4.5mm wall thickness
Rear 23.6mm diameter, 3.5mm wall thickness
Hotchkis:
Front = 31.75mm diameter, hollow, wall thickness = 4mm
Rear = 25.4mm diameter, hollow, wall thickness = 4mm
T1:
Front = 38.1mm/1.49" diameter, hollow, wall thickness = 6.35mm
Rear = 26.98mm/1.06" diameter, hollow, wall thickness = 6.35mm
