Old 08-15-2003, 04:21 AM   #1 (permalink)
Stupid ME
Accidentally dropped my brake cylinder cap down the side of the engine bay during header install. How do I gain access to the drivers side front quarter panel to retrieve the cap. I can not get my hand in the vent nor can I reach it from below. A speedy reply would be greatly appreciated....
doci is offline   Reply With Quote
Old 08-15-2003, 04:26 AM   #2 (permalink)
Location: Edgewater, MD Z06 Fests 2,3,4,5,6, Ocean & WinterFest 1&2
Say buddy,
You may try to remove the wheelwell liner, like when you install the vent screens. Or at least open it up. Not sure if this will help you. It's only a couple bolts/ screws, and the wheel being removed makes it easier. But then I may be wasting your time.
NCM # 23306 Fest Member 2, 3, 4, 5, 6, Ocean & WinterFest 1 & 2
Old 08-15-2003, 04:48 AM   #3 (permalink)
Originally posted by mjustmike
Say buddy,
This should work.
Old 08-15-2003, 06:46 AM   #4 (permalink)
Can you see it, and just not reach it? You can buy these remote 'grippy' things ... flexible cable with a spring-loaded button on one end and gripping claws on the other that open when you press the button. Pretty good for getting things you can see but not reach with your hand.
Jerry
'93 LT1 Coupe, Red/Tan, Auto
Jerry Velders is offline   Reply With Quote
Old 08-15-2003, 08:04 AM   #5 (permalink)
What he said. I did the exact same thing as you (except it was the clutch cylinder cap) and had one of those flexible cable grabber things and got my cap back in a minute.
'03 Anniversary Z06
100% Factory Bone Stock
Scruffy is offline   Reply With Quote
Old 08-15-2003, 10:47 AM   #6 (permalink)
One of the most used tools in my collection.
Old 08-15-2003, 10:56 AM   #7 (permalink)
I dropped something down there this year. Can't remember what it was... but, I was able to squeeze my arm straight down in there from the top and grab it. Safe to say, I don't have big arms.
The suggestion to take off the rear wheel well liner is a good one. I have had this off to get to my accusump which is tucked in the pocket where you dropped your cap. I have also had the passenger side one on and off numerous times swapping my PCMs back and forth.
I have found it is easier to take that cover off if you take the wheel off first. Not required, but gives you a little more room to work with.
Good luck.
Old 08-15-2003, 11:52 AM   #8 (permalink)
Thanks Guys, Was able to use a coat hanger from underneath. There is a vent opening right behind the front tire on the undercarriage.
How stupid is this? Speedratchet The Garage 17 01-09-2006 07:19 AM
Stupid is as stupid does... RC45 The Garage 11 08-13-2005 12:13 PM
Stupid Column Lock - Stupid Dealer Z06 Fever C5 Z06 - Grandstand 35 07-03-2005 07:47 AM
Never seen anything so STUPID!!! case2307 The Garage 25 12-02-2003 03:34 PM
I'm I stupid or what? InVision C5 Z06 - Grandstand 5 04-20-2002 03:44 AM
