For low speed AutoX I recommend FIRST upgrading to DA shocks and possibly VB&P Extreme springs before upgrading to a stiffer bar. But T1 bars can be used on an AutoX car if set up correctly. For AutoX you want to maintain quick transition rates, especially in Slalom, and then progressive roll resistance.
For high speed track work I recommend T1 bars be added with DA shocks initially.
I do not recommend the Hotchkis bars. Not because they are inferior; it's just because although they are slightly larger in dia. than OEM C5 Z06 bars thay have thinner walls which nets almost equal roll resistance. The only thing they might have is being slightly more progressive. The difference is almost imperceptable.
I also recommend that you use teflon lined Adjustable Heim Jointed spherical bearing end links. The non teflon lined need more maintainance and are noisier.
Besides roll resistance control in a stiffer bar the Adjustable end links allow more suspension adjustment. The OEM set up does not allow independant setting of ride heiight and corner weight. The Adjustable sway bar end links allow you to preload the corners somewhat and have a less dependant ride height. (Of course coilovers is the ultimate answer to independant adjustability of all suspension parameters).
A few cautions here about installation:
- Without the endlinks attatched the bar should rotate in it's mounts freely, by hand without effort.
- The mount bushings should be greased with a Lithium or Silicon based grease. They should be removed, cleaned, inspected and regreased at least once a year. I prefer the white Lithium grease for the bushings.
- OEM mounts can be used with the larger T1 bushings BUT they MUST be shimmed. Use 3-4 stainless steel fender washers.
- Adjustable heim jointed end links need weekly maintainance including cleaning and reapplication of a light grease coating. I prefer the red spray Silicon grease.
- Initially, the adjustable end links should be installed at their Shortest length. They are then 1/4" longer than OEM. They can be adjusted longer as need be to increase static preload or roll resistance as necessary.
- When measuring or setting corner weight or Cross Corner Weight % Difference anything other than an OEM bar with OEM end links MUST be dissconnected.
Some sway bar pearls:
- You can safely install either just the front bar or both bars of a matched set, such as T1 bars
- NEVER run a rear bar that is stiffer than the front UNLESS the front spring rate has been increased measurably. Ie. NEVER install a just a T1 rear bar without the T1 front bar or incresed front spring rate.
For basic tuning consult:
http://www.wtrscca.org/tech.htm
Some applicable available sway bars are:
1. Hotchkis - only slightly stiffer than OEM
2. OEM C6 Z06 - in between OEM C5 Z06 & T1
3. T1 bars
4. Pfadt Engineering Bars Custom adjustable bars and end links
