Old 01-19-2004, 02:20 AM   #1 (permalink)
Switch from low to high octane fuel tables?
When the PCM records a few incidents of spark knock it will lock the engine into the low octane fuel table.
Is there any way to force the PCM to go to the high table other than adding 5-gallons of gasoline?
At the track in the hot summer months, with low octane fuel, I've had the car go into the low tables. Even though I add 5-gallons of high octane gas, unless it has time to circulate completely thru the fuel system and get to the injectors before I make another pass, it will get a few incidents of spark knock on the old fuel in the fuel rails and that will cause the PCM to start using the low octane tables again, wasting the high octane fuel I just put in.
"Never ever stifle someone's creativity." - Sandra Shaw
FRISKY is offline   Reply With Quote
Old 01-19-2004, 12:22 PM   #2 (permalink)
Send a message via ICQ to The Highlander
No... it has been discussed greatly at EFILIVE.com
The Highlander is offline   Reply With Quote
High Octane or does it matter? FRCLandon FRC / Hardtops 11 12-14-2004 09:30 AM
FS: High Wattage Xenon Plasma High and Low Bulbs atz06 Member Sales - Parts & Cars 0 12-04-2004 01:22 PM
Fuel Additive / Higher Octane Fuel....? niphilli C5 Z06 - Grandstand 29 01-29-2004 01:28 AM
High Octane Fuel vetteheadracer C5 Z06 - Grandstand 7 07-10-2003 06:07 AM
100 octane fuel vs stock pump 93 octane - tested george Racing 17 07-15-2002 09:32 AM
