Originally posted by tblazeC5
If you read your hand book it states something like, if your temperature never goes below 0 degrees F (much colder than freezing) you can use 10w-30.
As far as start up, I’m more worried about protection when screaming through Death Valley at 130mph with the temp 110 - 120 degrees.
But technically, 5W-30 and 10W-30 have the same viscosity when at the same hot temperature (the very meaning of the viscosity numbers), so 5W-30 and 10W-30 should give the same high temp protection ... ie, 30 weight oil.
The viscosity at cold temps is different (5W vs 10W), and yes the 5W will flow more/faster at cold startup. GM recommends 5W-30 all the time, but does say in the owner's manual that 10W-30 is acceptable if ambient temp is above 0 deg F.
