Old 03-15-2004, 07:23 PM   #1 (permalink)
those with CF hoods please check in
Were you able to use your same shocks that hold up the hood? when they installed my hood they were not able to use them because the shocks were so tight that trying to push down on the hood to close it might crack and break it. any thoughs on how i could fix this would be great.
02 silver ZO6 -tint, C5R w/ stage II HID , turn signal black outs, lowered (most say slammed ) LGM homemade headers/off road pipes/x-pipe hurst shifter, borla stingers Reus Systems Custom Z06 Audio System and so much more...so much for being stock!!
qs_zo6 is offline   Reply With Quote
Old 03-15-2004, 07:41 PM   #2 (permalink)
How about just using 1 shock?
EFI Unlimited
EFI-1 is offline   Reply With Quote
Old 03-15-2004, 07:57 PM   #3 (permalink)
Can't ya buy softer shocks? The lighter weight hood should have softer gas shocks. What are they recommending at the place where you bought the hood?
Zrod is offline   Reply With Quote
Old 03-15-2004, 08:02 PM   #4 (permalink)
MikesZ06's Avatar
No problems with the shocks on my hood.
Sorry, no help here.
9.87 at 141mph
& 2007 Black C6 Z06
Old 03-15-2004, 08:21 PM   #5 (permalink)
Look for CE '04 shocks they may be different. I'll take a look at mine to see if there is a number on it. I'll check back in here in a minute.
Z06Nut.smugmug.com
z06nut is offline   Reply With Quote
Old 03-15-2004, 08:28 PM   #6 (permalink)
Ok I'm back...
On the shock it says: Stabilus Sometown?, N.C. U.S.A (zip code)
7295KA 0495N 339/03 B15
Mine weighs about 20.5 lbs. I hope this helps.
Old 03-15-2004, 09:58 PM   #7 (permalink)
[IMG][/IMG] Where are the shocks bolting up to. Are they actually on the carbon fiber mold or are they like the MCM hood? Who's hood is this-have not heard of any problems like this.
n2toys is offline   Reply With Quote
Old 03-15-2004, 11:39 PM   #8 (permalink)
EFI-1- i think 1 shock would have the same problem of not closing evenly and having a chance of crackin the hood.
z06nut- thanks for the info- i will make some calls tomorrow to find them.
n2toys- the hood is just like the stock hood but made of cf and the shocks bolt up in the same place.
im thinking my original shocks just came tight. i think the cf hood only weighs 13-15lbs. i was able to walk around with the hood with one hand and think nothing of it.
if anyone else has ideas that would be great.
thanks guys
Old 03-16-2004, 08:03 AM   #9 (permalink)
Man I hate to hear that. I have MCM hood and no problems but, when I had the Halltech hood before "I sent it back because of flaws" my body shop said there was no way I could use the shocks because it would push up the hood. It weighed in at 12-13lb's. Good luck to you
Z06gman is offline   Reply With Quote
Old 03-16-2004, 05:22 PM   #10 (permalink)
With mine it still bends a little. It might twist a little more with less weight. I would try call the manufacture of the shock. One thing you might consider would be an actuator to rise and lower your hood. Some car show guys use them for the trunk lids and various other things. It's just a thought...
Old 03-16-2004, 05:33 PM   #11 (permalink)
hmm interesting idea. i have one that i used on a amp rack i built. it would be very tick to see the hood open by remote
Old 03-17-2004, 03:04 PM   #12 (permalink)
Just push down if it breaks you bought the wrong hood and got ripped
Vis Cf Hoods defender The Garage 0 09-13-2005 03:24 PM
why hoods so expensive? robiferretti C5 Z06 - Grandstand 22 07-20-2005 01:06 PM
FS: Magnuson Hoods Black_Magic Member Sales - Parts & Cars 2 01-17-2005 07:12 PM
Anyone with RK Sport hoods? Matt69-ZO6 C5 Z06 - Pit Road 4 09-25-2004 05:48 AM
Available Hoods???? lightningz06 Vendor Sales - C5 17 03-21-2003 09:50 AM
